[HELP] AUDIOPHONICS I-Sabre V3 DAC ES9023 TCXO
Re: [HELP] AUDIOPHONICS I-Sabre V3 DAC ES9023 TCXO
Postby justsomeguy » 08 Aug 2016, 22:56
justsomeguy
Postby justsomeguy » 08 Aug 2016, 23:00
So I've finally got my power supply (9V 3A) for the DAC Pi3 setup.
I connected the the power button to the Sabre V3. Everything boots up when I press the button.
However, the blue LED on the power button keeps flashing blue. Is that an issue? How do I stop it from blinking?
Thanks!
justsomeguy
Postby rikardo1979 » 09 Aug 2016, 05:48
rikardo1979
Postby mihneanu » 28 Nov 2016, 20:05
Hi there,
I am planning to purchase RaspDAC Kit DIY Network player Raspberry Pi 3.0 & DAC Sabre V3 from http://www.audiophonics.fr, and the recommended Linear Regulated Power Supply EMI RFI Filter 6V 3.5A 25VA:
http://www.audiophonics.fr/en/diy-dac/a ... 11136.html
http://www.audiophonics.fr/en/hi-fi-pow ... 11363.html
I hope that everything will work out well, I guess 6V 3.5 A will be enough to power an USB HDD, correct?
And please tell me, there is a special power cable needed, the 55 Euro cable they suggest it's kind of overkill : http://www.audiophonics.fr/en/power-sup ... 10003.html
Do you have an alternative?
Thank you, I can't wait to share with you my experiences!
Mihnea
mihneanu
Postby DJ le Roi » 11 Mar 2017, 15:54
Hello, I have a question about this dac which I just bought.
I bent GPIO pins 2 and 4 from the Raspberry Pi and mounted the Dac on my Pi. Then I fed the Pi and the Dac separately with TWO 5V powersupplies. And it works, I am listening to music. My question is: Is this safe? This combination was designed to work with ONE 6V powersupply ? Is my setup with TWO 5V powersupplies damaging the dac?
I hope someone can answer my question!
DJ le Roi
Postby Stephane » 11 Mar 2017, 16:20
What is the benefit of having two separate power supplies ?
What kind of power supply are you using for the DAC board ?
Stephane
Postby DJ le Roi » 11 Mar 2017, 16:26
Thanks for your reaction.
The reason is that I do not have a 6V powersupply but that I do have a linear 5V powersupply. With this linear 5V PSU I feed the Dac. I feed the raspberry Pi with a good switching powersupply.
DJ le Roi
Postby DJ le Roi » 16 Mar 2017, 08:04
DJ le Roi
Postby phildaintree » 18 Nov 2017, 06:19
I purchased a AUDIOPHONICS RaspDAC I-Sabre V3 - Kit DIY Streamer Raspberry Pi 2 / 3 & DAC after online recommendations
https://www.audiophonics.fr/en/diy-dac/ ... 10384.html
(I am playing it through B&W 804s ->Perreaux 2150 power amp and a yamaha pure direct preamp.)
I got there with both the power switch and the display in the end thanks to Frank's and Dhrone's work and postings - really big thanks guys.
https://github.com/dhrone/Raspdac-Display
After the trauma of getting it assembled and software configured correctly I was expecting great things for the sound..... but honestly there is very little improvement over my existing raspberry pi and Chinese PiFi DAC+ at $24 + $39 for the Raspberry Pi
https://www.aliexpress.com/store/produc ... d4ce9hvQHq
Given the total absence of instructions for the audiophonics and the high price I have been dissappointed :-( Perhaps I had unrealistic expectations.
For the benefit of other audiophonics DIY assemblers I had most trouble with the power switch - as the switch came with a wire soldered onto the NC terminal of the switch but it should have been on the C terminal. Only when I realised this after a day of reading the french audiophonics forums via google translate did I crack the solution. I am sure most would have given up having wasted 200 Euros.
If you are considering an audiophonics Sbare V3 DAC ES9023 TCXO - then you do get a nice case and the display and the switch with some effort - but do not expect huge sound quality improvements over the cheapy DAC above. Maybe that one is a particularly good one - it certainly looks like damn good value next to the Audiophonics.
phildaintree
Postby Ripa » 05 Oct 2018, 15:19
Ripa
