rpi2 with iQaudIO PI-DAC+, no audio
Postby gerardgerard » 05 Aug 2016, 06:37
gerardgerard
Re: rpi2 with iQaudIO PI-DAC+, no audio
Postby ICLlP » 05 Aug 2016, 08:46
Does it need the unmute command, as with 0.3?
IQaudIO unmute
[root@iqaudio ~]# echo "22" > /sys/class/gpio/export
[root@iqaudio ~]# echo "out" > /sys/class/gpio/gpio22/direction
[root@iqaudio ~]# echo "1" > /sys/class/gpio/gpio22/value
ICLlP
Postby gerardgerard » 05 Aug 2016, 09:13
Based on your comment, I've followed this post
raspberry-pi-3-unmute-iqaudio-digiamp-t3479.html
But when I check if the script has worked, it is not clear. An "export" file is created but if I try to nano or cat it I get a Permission Denied (but I am root). And the other two, when I ls the directory they don't seem to be there.
How can I do this?
Thanks,
UPDATE: Just hold on, I've now realized I'm using the 5v power source, and I should be using a 15-19v power source. I'll post here if that solves the problem or not (can't try it right now).
gerardgerard
Postby gerardgerard » 05 Aug 2016, 19:08
No no, I´ve messed it, the DAC plus doesn´t need any specific power source, it is powered by the rpi itself. Then the problem persists, I cannot get any audio :(
gerardgerard
Postby ICLlP » 05 Aug 2016, 20:10
My advice was based on page 28 of this http://www.iqaudio.com/downloads/IQaudIO.pdf
ICLlP
Postby gerardgerard » 08 Aug 2016, 20:10
Ok, at the end I've had to run alsamixer (ssh) and there, select the IQAUDIO card and increase the volume, then sound has appeared :D
Great!
*As indicated in the manual, thanks to the previous post
gerardgerard
