[MOD] New function added: Alarm and Volume fade over time
Re: [MOD] New function added: Alarm and Volume fade over tim
Postby lanlor » 18 Jan 2016, 18:55
That worked! Thank you very much and best regards.
lanlor
Postby Pilou007 » 28 Jan 2016, 10:22
I have the same pb as lanlor but when i write
pacman -S cronie
rasp answers me :
[root@runeaudio ~]# pacman -S cronie
resolving dependencies...
looking for conflicting packages...
Packages (2) run-parts-4.4-1 cronie-1.4.12-1
Total Download Size: 0.08 MiB
Total Installed Size: 0.35 MiB
:: Proceed with installation? [Y/n] y
:: Retrieving packages ...
error: failed retrieving file 'run-parts-4.4-1-armv7h.pkg.tar.xz' from mirror.ar chlinuxarm.org : The requested URL returned error: 404
warning: failed to retrieve some files
error: failed retrieving file 'cronie-1.4.12-1-armv7h.pkg.tar.xz' from mirror.ar chlinuxarm.org : The requested URL returned error: 404
error: failed to commit transaction (unexpected error)
Errors occurred, no packages were upgraded.
what can i do ?
Pilou007
Postby hondagx35 » 28 Jan 2016, 12:35
Postby Pilou007 » 28 Jan 2016, 22:34
Pilou007
Postby SlF » 03 Feb 2016, 11:22
SlF
Postby restinpieces » 28 Feb 2016, 22:38
Very nice! I really like this mod.
I tinkered a bit with it and added some more control and the function to add multiple alarms.
Any playlist created in the queue window can be selected as Alarm playlist.
The only problem is I am very bad at styling :( So the look isn't that great and it has some display problems with mobile devices.
If someone is able to add some style to it I would be really happy!
Picture:
Extract the alarm.php file from the zip and replace /var/www/app/templates/alarm.php with it.
alarm.zip
(2.14 KiB) Downloaded 565 times
restinpieces
Postby cyber7 » 18 Jun 2016, 13:31
Hi Guys
Almost 15 months later, the release is still running!
I have had no failures and the system runs without stop :D
My son was born on the 21 Feb 2015 and the radio has been playing lullabies in his room since then. The radio release just does not die!
kind regards
cyber7 (aka Aubrey Kloppers; Cape Town; South Africa)
To err is human, to err again is machine!
cyber7
Postby nanoqui » 28 Jul 2016, 00:01
nanoqui
Postby hondagx35 » 28 Jul 2016, 06:59
Postby nanoqui » 28 Jul 2016, 22:22
thanks...
I did a new install of the alarm and fade function ontop of a new rune image. Everything works perfekt now. Must have somehow screwed it up doing something else. Thanks again!
Cheers,
-Q
nanoqui
