[SOLVED]Cover art cannot get to work.
Postby windwalker » 26 Jun 2016, 06:51
Update :
I changed the mount from NFS to SMB/CIFS.
Then the cover art worked !
I installed the v0.3-beta RuneAudio on my RPi3.
I mounted my NAS in RuneAudio by NFS.
Everything seems works fine , ID3 tags , playing...etc.
But I got a problem about cover art.
The cover art is just not showing , no matter the cover art is a cover.jpg file in the song folder or is embadded in ID3 tag.
And no matter I use MPoD or RuneUI , it always show the default image.
I use the original nginx.conf , and the original coverart_ctl.php .
And in MPD settings , I choose the user/group to root:root.
About mount flags , I also use the default flags "nfsvers=3,ro".
Is there anything I can try?
Thanks.
windwalker
Re: Cover art cannot get to work.
Postby hondagx35 » 26 Jun 2016, 21:18
Postby windwalker » 27 Jun 2016, 12:36
windwalker
Postby windwalker » 03 Jul 2016, 17:43
I tried to pull latest code from Git to var/www .
But after I reboot and hard clean cache , it still the same.
The cover art still show the default image. :/
Any idea can help show the correct image file in the folder?
Thanks~
windwalker
Postby hondagx35 » 03 Jul 2016, 19:01
Hi windwalker,
/mnt/MPD/NAS/Synology/原聲帶/Child of Light/folder.jpg
I would try to change this folder name, maybe the chinese characters are the problem.
Postby windwalker » 05 Jul 2016, 10:44
I tried the all ASCII chart path.
for example mnt/MPD/NAS/Synology/folder.jpg and play audio file under mnt/MPD/NAS/Synology/
It did not work , either :/
windwalker
Re: [SOLVED]Cover art cannot get to work.
Postby windwalker » 05 Jul 2016, 17:39
windwalker
