[SOLVED] No access/boot?
Beaglebone Black related support
Postby beanstalker » 02 Feb 2014, 08:04
beanstalker
Re: No access/boot?
Postby ACX » 02 Feb 2014, 12:58
Hello beanstalker, it seems your BBB is not booting from SD... try to follow this order:
1) plug the power off
2) keep pressed the USER/BOOT button ( it's called "Boot Switch")
3) plug the power connector in while keeping the button pressed and wait for 20 secs
You should see all the 4 blue leds on for a while, then all off and then an activity. That means that the boot with RuneAudio was successful.
Let me know if it works.
Re: No access/boot?
Postby beanstalker » 03 Feb 2014, 06:12
Hi ACX,
Thank you, that worked perfectly. Listening to RuneAudio right now, very happily!
Seems obvious now that you pointed it out!
Just as a side note, to me it sounds much better on the BBB than the Rpi. Better performance, no clicks or stutters at all.
Brilliant software and UI, thanks for all of the hard work!
Cheers,
Jack
beanstalker
Re: [SOLVED] No access/boot?
Postby Nasnl » 05 Apr 2014, 23:05
Hi Guys,
I have about the same thing: have flashed the SD-card, boot up the BBB with the boot switch pressed until the 4 LED's shop blue, then turn off and then start showing activity.
My router sees the BBB as runeaudio (so something went ok), but I cannot access the GUI in any way, not even by IP-number or through windows network.
Any idea what I could try next?
Nasnl
Postby arada n » 19 Jun 2016, 05:53
I thought I'd just jump in on this thread.
I am getting the same behaviour as described with four leds shining.
The only way to boot is to do a boot button start up.
It does not seem the good way to start up.
Hence my question is, is image provided intended for flashing to BBB emmc or intended to be run from flaah drive on day by day basis?
I have followed the steps to create the image indicated here at Rune audio for windows
On the other hand I have another sd with vlumino flashed using mac book pro and it starts up from the sd card directly.
I am just wondering
Whether I am using the image in the wrong way. For day to day use instead of flashing
Or I have an issue with my set up which needs to be solved
Thanks.
Oleg
arada n
Return to Beaglebone Black
