24/192 no output via usb - silence
Postby reddyshoey » 23 May 2016, 22:45
Hello, frends!
I have rpi2b and yulong d200 dac connected. Everything is working fine except the files 24/192 and above. It is simply no signal on dac, through runeaudio shows that playback is working. Sorry can it be fixed, what should i look into?
reddyshoey
Re: 24/192 no output via usb - silence
Postby rastus » 24 May 2016, 00:36
rastus
Postby reddyshoey » 24 May 2016, 07:58
reddyshoey
Postby PeteB » 24 May 2016, 15:27
PeteB
Postby reddyshoey » 24 May 2016, 16:14
reddyshoey
Postby hondagx35 » 24 May 2016, 17:24
Hi reddyshoey,
please post your debug data.
Also trying the latest version could be an option.
Postby PeteB » 24 May 2016, 17:36
PeteB
Postby reddyshoey » 24 May 2016, 19:35
reddyshoey
Postby reddyshoey » 24 May 2016, 20:10
update on the situation. it seems that problem is in the DAC itself. I just tried to play same files via this dac on my windows pc, using foobar. Dac showed the same picture: "USB input No signal".... WTF?
reddyshoey
