24 bit 192khz playback stuttering
Postby goldenyears » 14 May 2016, 21:23
I was able to setup my NAS mount thanks to the help of Frank and others - many thanks!
I have noticed that there is severe stuttering when playing 24 bit 192khz files which didn't seem to be a problem before. I tested a few 16bit 44.1khz and they are fine but the 24 bit 96khz files I tested occasionally stutter at the beginning of playback. I am using a wifi dongle with wireless correctly configured and haven't moved the pi to a different location so I don't think it's a problem with the signal strength as it would have occurred before. I would appreciate it if someone could help me out.
Thanks,
Al
goldenyears
Re: 24 bit 192khz playback stuttering
Postby ACX » 14 May 2016, 23:48
Hi goldenyears, have you already tried to tweak the "Audio buffer size" and the "Buffer before play" settings in the MPD section?
Postby rastus » 15 May 2016, 11:26
rastus
Postby Jim Creek » 15 May 2016, 19:53
Jim Creek
Postby goldenyears » 15 May 2016, 20:18
Thanks to all who replied. I've played around with the audio buffer size and buffer before play values but still have the same problem. It's really strange as when I setup the NAS mount everything was running smoothly (including 24/192 files). As I mentioned before, I haven't changed the configuration or moved the pi further away from my modem. Could something have happened to the dongle?
goldenyears
Postby PeteB » 15 May 2016, 23:04
PeteB
Postby rastus » 16 May 2016, 00:02
rastus
Postby Jim Creek » 16 May 2016, 03:00
Jim Creek
Postby rastus » 16 May 2016, 04:25
rastus
Postby PeteB » 16 May 2016, 04:57
I think we need a simple way to measure actual WiFi throughput, FROM whatever NAS-type device a user has, TO RuneAudio/Arch. There have been a few threads like this one, including a couple of mine.
Since I usually use some kind of Linux-y box to store my media files, as well as a laptop running Ubuntu/Linux to get online, I usually install a program called iperf for that purpose.
Unfortunately that is of no help to the majority using Windows and Apple machines, and my limited networking skills do not extend very far.
I am willing to collaborate on a solution and do some testing, but the heavy lifting would have to come from someone with more knowledge than I have... :mrgreen:
@rastus: I understand there are ten different kinds of people in the world... the ones who understand bipolar, and the ones who don't... ;)
edit:
Oh wait, that was bi-nary, right? .... nevermind ... :D
PeteB
