(solved) PI3 0.4 beta, wifi not ok
Postby TommyBoy » 25 Apr 2016, 19:19
RuneAudio_rpi2_rp3_0.4-beta_20160321_2GB.img
onboard wifi finds tons of weak networks my nabours, they are all listed as full signal,
my own routers are located 4 feet away, dont show up. none of them..
power off,
plug in a USB super cool wifi doungle with external antenna (works perfectly with old pi and 0.3 rune)
boot up my pi3 in networks now I see one wired, and two wireless, however NONE of the wireless, see any connections..
feeling sad.. feeling lost, stuck again..
TommyBoy
Re: PI3 0.4 beta, wifi not ok
Postby hondagx35 » 25 Apr 2016, 21:28
Postby TommyBoy » 25 Apr 2016, 21:57
HA HA you rule !!
my two wifi systems use ch12 and ch 13 :-)
EDIT : changed wifi router to CH6 and CH7 now I see them, now i can access them just fine.
ok, i need to figure out how to access and edit the files you suggest,
total noob with stuff like that.
EDIT : PLEASE HELP ME ??
how to edit the files and settings you suggest ?
the files are NOT on my SD card when I plug it back into a PC where stuff make sense to me :-)
TommyBoy
Postby hondagx35 » 25 Apr 2016, 22:37
Postby TommyBoy » 25 Apr 2016, 22:59
did not know about console access this way and never seen SSH before, but it was quite easy.
all you said, WORKED !!!
i am happy, better go to sleep now, it is 00:09
thanks a lot, tomorrow it is I2S fun,
I need to "convert" PI1 sound card to PI3 connector, it is going to be fun.
TommyBoy
