library search issues
Postby mikefc55 » 22 Mar 2016, 19:31
mikefc55
Re: library search issues
Postby PeteB » 22 Mar 2016, 19:46
Hi, and welcome, :)
Search seems to be only partially working in the Beta releases (if you get something like the screen cap in the link below). I assume there has been too much work with the new Pi 3 images to address those smaller issues.
PeteB
Postby mikefc55 » 22 Mar 2016, 20:04
thank you PeteB, being a newbie at this I wanted to ask first before I wasted time debugging. what u sent a screen grab of is the problem.I'll wait for new release.
mikefc55
Postby PeteB » 22 Mar 2016, 20:33
You are welcome. I think it is difficult for Frank and the other developers to work on these minor issues (I found several), and at the same time make new images for the RPi 3.
Out of curiosity, have you tried the up and down arrow keys while in the queue screen? It looks like when you use those to scroll up and down a screen at a time, the screen scrolls by more than the number of lines on the screen, skipping a couple lines each time.
PeteB
Postby mikefc55 » 22 Mar 2016, 21:04
just tried it, it actually mimicks the page down/up , it jumps to bottom/top of queue
mikefc55
Postby PeteB » 22 Mar 2016, 21:52
When I try it with more than 2~3 pages of tracks in the queue, the single arrow scrolls the number of lines visible, plus either two or three extra. The double arrow always takes me to the top or bottom of the queue.
You may have a newer image, I think I am one behind (no time to test a new one until next weekend).
I am sure the search will get fixed eventually.
I have both the DIGI+ and the DAC+, and I am just happy that that the hardware control on DAC+ finally works as one might expect, so I can now compare the digital output with an external DAC and the DAC+ without jumping through hoops... :D
Pete
PeteB
Postby hondagx35 » 22 Mar 2016, 22:55
the buttons do exactly (most) what they should do.
The double arrows scroll to top and bottom, the single arrows scroll page wise.
There was a little error in calculating the page height.
This is fixed now (update via git).
Postby hondagx35 » 22 Mar 2016, 23:00
Postby hoverdonkey » 02 Apr 2016, 12:50
hoverdonkey
Postby Beelzebassie » 02 Apr 2016, 15:18
Beelzebassie
