[solved] Reboot from command line mutes the soundcard
Postby Der Vogel » 28 May 2014, 13:26
Hi guys,
I had an and I tested lots of commands from the console, formatted several time SDCard and so on.
Until I realized the following: it seems that using the commands "reboot" or "halt" from the console makes RuneAudio stops completely to work with my external sound card. From the GUI, I can see the song progression but I get no output. However, it seems to continue to work for HDMI output. Rebooting from the GUI did not help.
I solved the problem only with a new installation of RuneAudio, and using only the RuneAudio GUI to halt or reboot.
I am happy to conclude that updating Archlinux or adding a partition on the SDCard with my music was not the problem.
EDIT: the sound card was just muted after restart. See below.
Der Vogel
Re: reboot from command line breaks RuneAudio
Postby Midnight » 28 May 2014, 13:41
Maybe your output is just muted? Check your mixer settings with alsamixer after the reboot. I've never had problems with rebooting from command line.
Midnight
Moderator
Postby Der Vogel » 28 May 2014, 14:23
Der Vogel
Re: reboot from command line mutes the soundcard
Postby Der Vogel » 29 May 2014, 06:28
Ok, solved. After using alsamixer, I enter the command "alsactl store" and now my sound card is not muted anymore at startup.
See and .
I do not set the title of this issue as "solved" yet because I do not understand why the first time using "reboot" in command line made this issue happen.
Der Vogel
Postby ACX » 29 May 2014, 11:48
Hi Der Vogel, we already solved the problem in v0.3: sound card settings (volume level and mute/unmute) are stored and not lost after a shutdown/reboot.
Postby Der Vogel » 30 May 2014, 07:52
Ok then. I change the status to "solved".
Der Vogel
Postby Midnight » 05 Jun 2014, 15:37
Midnight
Moderator
Postby ACX » 11 Jun 2014, 13:09
Return to Bug report
