Shutdown is very slow
Postby Elliott B » 15 Jan 2014, 19:43
Elliott B
Re: Shutdown is very slow
Postby ACX » 15 Jan 2014, 22:35
I was reading the same article today! This point in particular:
http://freedesktop.org/wiki/Software/sy ... eventually
We are aware of the problem but we still didn't fount a satisfatory solution. It seems we are not the only ones to suffer this weird behaviour:
https://bbs.archlinux.org/viewtopic.php?id=170756&p=1
PS: Elliott B, you already are our most prolific bug reporter :D Just let me tell you that your cooperation on this is really appreciated. Thank you and keep it up!
Postby tux » 27 Mar 2014, 18:27
I did some tests in my custom archlinuxARM/mpd distro. I also suffered from slow shutdowns. I decided to replace netctl with systemd-networkd. The change was extremely easy and the configuration is as easy as netctl was.
After this change, boot is faster and shutdown is finally as it should be.
tux
Postby ab.eccolo » 09 Mar 2016, 21:17
also here very slow shutdown.
I've activated the debug and I've found a lot of errors like:
Failed to send unit remove signal for <.....> Transport endpoint is not connected, any ideas?
ab.eccolo
Postby hondagx35 » 10 Mar 2016, 17:50
Hi ab.eccolo,
without more information it's very hard to help.
- device (RP1, RP2, Odroid, Cubietruck)
- shutdown via user interface UI or via console?
- updates installed
- is it a new installation or a older one?
- free space on sd card (df -h)
Postby ab.eccolo » 12 Mar 2016, 11:08
Thank a lot Frank, you are right, without any information is not simple:-)
So,
-device -> raspberry 2
-shutdown -> i use a ATXRaspi board to shutdown the raspberry, so I've enabled the rc-local service in order to run in background a script that execute "systemctl poweroff" if I press the power button.
-yes update rune ui instelld
- new installation (if with my modifications can be called fresh instalation again..... :-)
[root@runeaudio ~]# df -h
Filesystem Size Used Avail Use% Mounted on
/dev/root 1.7G 1.4G 254M 85% /
devtmpfs 367M 0 367M 0% /dev
tmpfs 371M 0 371M 0% /dev/shm
tmpfs 371M 316K 371M 1% /run
tmpfs 371M 0 371M 0% /sys/fs/cgroup
tmpfs 371M 804K 370M 1% /tmp
logs 5.0M 44K 5.0M 1% /var/log
rune-logs 5.0M 1.4M 3.7M 27% /var/log/runeaudio
/dev/mmcblk0p1 100M 13M 88M 13% /boot
[root@runeaudio ~]#
Thanks again for your support
EDIT -> I've expaned the partition, new df:
/dev/root 15G 1.4G 13G 11% /
tmpfs 371M 20K 371M 1% /tmp
rune-logs 5.0M 1.3M 3.8M 26% /var/log/runeaudio
//nas_dlinkVolume_1/Music 915G 725G 191G 80% /mnt/MPD/NAS/Libreria
EDIT 2 : as workaround to poweroff the runeaudio in the script I've set instead of systemctl poweroff:
sync ; sync ; poweroff -f
I know that is not the best way to shutdown a distro, but for now works...
@tux, is there any tutorial in order to set the modification on netctl? ( I don't still know very well systemd ....)
ab.eccolo
Postby hondagx35 » 12 Mar 2016, 13:12
Postby ab.eccolo » 12 Mar 2016, 21:51
It works perfectly! Thanks a lot :-)
Great support for a great (good, very good) sound oriented distro :-)
Thanks again.
ab.eccolo
