Radio stream are not working
Postby fohnbit » 23 Jan 2016, 12:12
this link wotk in Squeezbox Server and VLC:
http://mp3stream7.apasf.apa.at:8000/listen.pls
Why not in RuneAudio?
Thank you!
fohnbit
Re: Radio stream are not working
Postby hondagx35 » 23 Jan 2016, 12:43
Hi fohnbit,
you have to add the radio url not a pls.
In your case it is:
Postby fohnbit » 23 Jan 2016, 13:03
Hello Frank,
fine, it works.
Thank you for your support!
fohnbit
Postby hondagx35 » 23 Jan 2016, 13:10
Hi fohnbit,
the easiest way to add webradio is to use dirble.
Postby fohnbit » 23 Jan 2016, 13:59
Hello Frank,
yes, this seems the easiest way.
With the search button I found my local Radio stations!
Thank you!
fohnbit
