The new $5 Raspberry Pi Zero
Re: The new $5 Raspberry Pi Zero
Postby RandirVithren » 04 Jan 2016, 11:38
my situation is a little bit different.
moode works also fine incl. hdmi output at pizero.
but volumio starts first with a sdram error (led blinking 8 times) - after a kernel-update on a working rpi B+ it works fine.
runeaudio doesn't start or boot - no activity on led.
in fact:
pi zero works
sdcard works
supply works
rune-img doesnt work - why? i tried all rpi1 images without success
greetz
RandirVithren
Postby mRqS » 04 Jan 2016, 15:19
Marek
mRqS
Postby RandirVithren » 07 Jan 2016, 23:22
does nobody have an idea what can i do to bring the rpi0 booting with rune?
RandirVithren
Postby mRqS » 07 Jan 2016, 23:28
I've figured out how to fix Volumio (but not Rune, which is on Arch): put the card in older RPi1 and update kernel via:
sudo apt-get update
sudo apt-get install binutils
sudo rpi-update
Once finished, put the card into Pi0 and...voila! :)
Marek
(via Tapatalk)
Marek
mRqS
Postby RandirVithren » 08 Jan 2016, 18:52
maybe it's done
first successful boot on a rpi0.
same procedure as volumio, but only with different commands.
1. boot rune with a rpi1 (A or B/B+)
2. update/upgrade arch linux with
sudo pacman -Syy & sudo pacman -Su
3. update rune with
cd /var/www
git pull
curl -s -X GET 'http://localhost/clear'
4. reboot
5. put sdcard in rpi0 and boot
RandirVithren
Postby mRqS » 08 Jan 2016, 19:56
Great! Don't forget to put
arm_freq=1000
gpu_freq=300
core_freq=400
over_voltage=6
force_turbo=1
To config file to get it to the default speed of PiZero
I'm going to check your fix and try Rune :)
Thanks!
Marek
(via Tapatalk)
Marek
mRqS
Postby chsims1 » 03 Mar 2016, 16:27
Has any one managed this successfully? I just tried and the pacman update broke the system (wouldn't boot afterwards)
chsims1
Postby BayleeWylie » 04 Mar 2016, 21:49
Raspberry Pi 2
IQaudIO PI-DAC+
HifimeDIY U2 Sabre ES9023
Sennheiser HD598SE
BayleeWylie
Postby chsims1 » 17 Mar 2016, 07:39
Finally got round to trying this ... unfortunately it doesn't work. Left again with an unbootable Pi :( .... just red power led showing.
chsims1
Postby mnelsoneorm » 24 Apr 2016, 08:04
Anyone know if there will be a dist for the zero in the near future (for those of us who have no pi1 to set it up)?
mnelsoneorm
