[SOLVED] MPD Database Update not picking up ALAC m4a files
Postby tc-fi » 24 Jan 2014, 00:22
II've mounted a folder located on a Win7 box that contains some Flac and ALAC files and only the Flac files show up after Database Update.
tc-fi
Re: MPD Database Update not picking up ALAC m4a files
Postby pacsabi » 29 Jan 2014, 17:06
Same problem, samba apple time capsule.
pacsabi
Postby bigeyes0x0 » 30 Jan 2014, 05:10
Same problem is posted here rpi-runeaudio-0-2beta-does-not-recognized-m4a-t71.html
The reason is ffmpeg decoder is required to play m4a and runeaudio has it disabled by default inside in /etc/mpd.conf -> workaround: you just need to enable it and update mpd database. Be aware that any custom modification to mpd.conf will disable the web gui editor, that's why it's best to make all the changes you need first then edit this file later.
bigeyes0x0
Postby ACX » 30 Jan 2014, 17:37
We left ffmpeg decoder disabled by default because we experimented problems with the database update (in some situations it couldn't be completed successfully).
We are going to add the option to manually activate it from the next 0.3 release.
Postby tc-fi » 30 Jan 2014, 18:46
tc-fi
Postby tc-fi » 30 Jan 2014, 18:48
tc-fi
Postby pacsabi » 31 Jan 2014, 17:49
pacsabi
Re: [SOLVED] MPD Database Update not picking up ALAC m4a fil
Postby jonclancy » 15 May 2014, 14:25
For a beginner (but can use PuTTY), how do I edit the config file please?
decoder {
plugin "ffmpeg"
enabled "no"
decoder {
plugin "ffmpeg"
enabled "yes"
Many thanks
Jon
jonclancy
Postby jonclancy » 16 May 2014, 18:24
Ah - I found nano and edited the /etc/mpd.conf file.
Restarting to see if it's worked!
jonclancy
Postby jonclancy » 16 May 2014, 19:13
Working!!! :D Sounds great!
jonclancy
