Hello this is Daniel from germany.
I have he following problem:
I use a Cubietruck with build in Wifi and Rune 0.3.
Connection with ethernet is just fine and Rune boots very fast.
But it wont connect to wifi with disconnected LAN.
With connected LAN it finds my network without problems. and when i connect the wifi, it works.
But if i restart or shutdown the cubietruck und disconnect the ethernet - it wont connect to wifi again.
Tried with rune on SD Card, now in the NAND, but same problem.
Any suggestions how to solve the problem?
Thank you
Best regards
Daniel
