HifiBerry DAC+ Pro [solved for Raspberry B+]
Re: HifiBerry DAC+ Pro
Postby bknarf » 07 Nov 2015, 21:53
bknarf
Postby bknarf » 07 Nov 2015, 22:06
Bummer, now it appears that wireless is not working anymore :? Can this be caused by the kernel update? In the RuneUI the WLAN connection is still visible, but status is not connected (No IP assigned). I've deleted the Wifi profile and tried to connect again, but without success. I find it strange that at WiFi stored profiles, under Show, there is no profile visible. When trying to Add a new profile, it still doesn't show up. Somehow it appears that the WiFi settings are not correctly stored anymore? (It did work before)
bknarf
Postby °pdi° » 08 Nov 2015, 10:45
°pdi°
Postby hondagx35 » 08 Nov 2015, 11:11
Postby °pdi° » 08 Nov 2015, 11:18
you were faster, while i edit my post.
Klaus
°pdi°
Postby °pdi° » 08 Nov 2015, 11:57
°pdi°
Re: HifiBerry DAC+ Pro [solved]
Postby bknarf » 08 Nov 2015, 19:48
Is it really needed to add the kernel and cmdline entries in the config.txt? I mean, the name of the files didn't changed after the kernel update, right? In my case, on a RPi2, it seems i can boot without a problem after doing the update and without editing the file.
BUT ... after the kernel update, it appears I cannot connect to my WiFI again. To be sure, I've tried it again. Started with a fresh install of RuneAudio. Set up my WiFi, which works then. But after the kernel update and reboot the wlan0 connection does not want to connect anymore. Tried to delete the profile and add a new one (via WebGUI), but doesn't help.
Is there a way to have the correct driver for the HifiBerry DAC+ Pro loaded AND have working WiFi? ;)
FrankB
bknarf
Postby hondagx35 » 08 Nov 2015, 20:28
Postby bknarf » 08 Nov 2015, 21:21
Thanks for the suggestion. I installed crda and uncommented my country region in /etc/conf.d/wireless-regdom. After a reboot, nothing seems to be changed. Deleted the existing wireless profile again via the WebGUI and set up a new one, but still the same issue ...
FrankB
bknarf
Postby JeffD » 08 Nov 2015, 21:52
JeffD
