Does not work. When you turn on the browser, the gray screen and pointer turn on, the browser turns off and the screen goes dark.
When I turn on the browser.
The screen turns gray, a pointer appears if you turn it on when you turn on the browser.
chromium 88.0.4324.146-2
● localbrowser.service - Local Browser - Chromium
Loaded: loaded (/etc/systemd/system/localbrowser.service; enabled; vendor preset: disabled)
Active: active (running) since Sun 2021-02-21 10:56:07 UTC; 2s ago
Main PID: 1807 (sudo)
Tasks: 41 (limit: 2138)
CGroup: /system.slice/localbrowser.service
├─1807 /usr/bin/sudo /usr/bin/startx
├─1809 /bin/sh /usr/bin/startx
├─1824 xinit /etc/X11/xinit/xinitrc -- /etc/X11/xinit/xserverrc :0 -auth /tmp/serverauth.0OKZCM0tOg
├─1825 /usr/lib/Xorg -nolisten tcp :0 -auth /tmp/serverauth.0OKZCM0tOg
├─1855 /bin/bash /etc/X11/xinit/xinitrc
├─1859 matchbox-window-manager -use_cursor yes
├─1860 /usr/lib/chromium/chromium --app=
http://localhost --kiosk --incognito --no-sandbox --force-device-scale-factor=1
├─1904 /usr/lib/chromium/chromium --type=zygote --no-zygote-sandbox --no-sandbox --force-device-scale-factor=1
└─1905 /usr/lib/chromium/chromium --type=zygote --no-sandbox --force-device-scale-factor=1
10-30 seconds the browser turns off, the screen turns dark.
Active: failed (Result: exit-code) since Sun 2021-02-21 10:52:03 UTC; 22s ago
Process: 763 ExecStart = / usr / bin / sudo / usr / bin / startx (code = exited, status = 0 / SUCCESS)
Process: 1536 ExecStop = / usr / bin / killall Xorg (code = exited, status = 1 / FAILURE)
Main PID: 763 (code = exited, status = 0 / SUCCESS)
