alecs123
Thanks Rern...
The files were created by rhythmbox in ubuntu... then saved to the NAS... on versión 0.4b and 0.5b I had to modify the path but then just copied the .m3u files to /var/lib/mpd/playlists and that worked
I will try removing all EXT info, do you recommend a full path or relative path to files?
Thanks again
I just tried different paths and no dice... get this error
2011
error adding //192.168.0.104/musica/Waterboys - Unknown - 00 - The Whole Of The Moon.mp3: Access denied
PHP Notice: Undefined index: name in /srv/http/mpdplaylist.php on line 163
-1
this is how it looks now
//192.168.0.104/musica/White Snake - Unknown - 00 - Here I Go Again.mp3
//192.168.0.104/musica/White Snake - Unknown - 00 - Is This Love.mp3
Also tried with "/mnt/MPD/NAS/Musica" path where the NAS is mounted
lnoferin
This is my first post on this forum.
First, I would like to thanks all the people involved in this project because I found it very useful!
But I have a problem installing the addon: from the web ui I get this error
And the same using the root terminal
I am using this (from system info page)
Version e6 20201201 • RuneAudio
Hardware Raspberry Pi 3 Model B Plus Rev 1.3
SoC BCM2837B0 • 4 Cortex-A53 @ 1.4GHz • 1GB
Output Device
Kernel HiFiBerry DAC+
MPD 5.4.80-1-ARCH 0.22.3-1 59.411 0 3.267
Networks 192.168.1.241 b8:27:eb:7d:dd:85
Sources / • 2.6GB/15GB
Jaymass
This is fantastic! I’ve been struggling along with HiFiBerry os and Volumio neither of which are really usable with a touch screen,scrolling through tracks is sooooo slow, I stumbled over this forum post and I’m delighted,works exactly as I’d hoped it might! I do have a couple of questions though,I have a HiFiBerry Dac+ DSP on the way, I see it’s listed in the driver section does that mean I don’t need to instal the dsp tool kit or will I still need to when it arrives? Also is there a way to remove the volume control from the display,I’ve gone through settings a few times and can’t find an option? Thanks!
Edit: found the option for removing the volume display!
This software is fantastic, sounds gorgeous,looks great, functions smoothly and quickly ...honestly feels like an early Christmas present!
ray1112
I have Cirrus Logic Audio Card and Raspberry Pi 2.
Hardware Raspberry Pi 2 Model B Rev 1.1
Output Device Generic Cirrus Logic WM5102
Q1. How change audio card output (Line out or Headset)? RuneAudio 0.4b have it on MPD page.
Q2. Default mixer is not working (Hardware Volume Control is not working). RuneAudio 0.4b have it working well.
If I change mixer on MPD page to "HPOUT1 Digital" I have error on MPD page:
Errors: JSON.parse: unexpected character at line 1 column 118 of the JSON data
▮{ "devices" : [{ "aplayname" : "RPi-Cirrus" , "card" : 0 , "device" : 0 , "dop" : 0 , "format" : "" , "mixercount" : , "mixermanual" : "HPOUT1 Digital" , "mixertype" : "hardware" , "name" : "RPi-Cirrus" , "hw" : "hw:0,0" , "hwmixer" : "HPOUT1 Digital" }] , "audiooutput" : "Generic Cirrus Logic WM5102" , "audioaplayname" : "rpi-cirrus-wm5102" , "autoupdate" : false , "buffer" : false , "bufferset" : false , "bufferval" : false , "bufferoutput" : false , "bufferoutputset" : false , "bufferoutputval" : false , "crossfade" : false , "crossfadeset" : false , "crossfadeval" : false , "custom" : false , "customset" : false , "customval" : "customset" , "ffmpeg" : false , "normalization" : false , "reboot" : "" , "replaygain" : false , "replaygainset" : false , "replaygainval" : "" , "soxr" : false , "soxrset" : false , "soxrval" : "" , "usbdac" : "" }
Ears of Tin
Welcome to the Rune community.
Settings gear, Playback, volume button toggles on or off.
Jaymass
Thank you! I did find it after a while of playing, I also got an answer from HiFiBerry regarding the dsp board, it’s possible to use their os and save settings to the board itself then simply swap the card back to the rune one and the room correction,eqs etc will all still be active so a pretty simple solution there!
Loving the “roll the dice” mode, I may never turn this off again
haddock
Last weeks I've scrutenized my musiccollection for missing metadata en covers. After updating the library in runeaudio I notices a strange sorting order. Artistnames, bandnames starting with "The" are sorted apparently at random.
The sorted list starts with groups with names starting with "The". After that the other groups starting with "T" are listed. However in that list also groups with "The" are listed. The latter are not listed in the top part.
To visualize:
The 13th Floor Elevators
The Adverts
The Supremes
T'Pau
T. Rex
Taylor Swift
The Teardrops Explode
Tears for Fears
etc.
It looks like in some (random?) cases "The" is omitted.
In the metadata the names are spelled beginning with the. Listing the directory is also showing normal behaviour. List starts with T. Rex
Any ideas/suggestions?
Ears of Tin
haddock wrote Artistnames, bandnames starting with "The" are sorted apparently at random.
One man's bug is another man's feature. The word "the" is ignored in sorting. So in my collection "The Allman Brothers" are at the top and "The Zombies" are at the bottom. Numbers and special characters/punctuation come before letters.
If you have any music by the band "The The” your Raspberypi will burst into flames.
https://en.m.wikipedia.org/wiki/The_The
ray1112 wroteI have Cirrus Logic Audio Card and Raspberry Pi 2.
On RuneAudio 0.4b, post results:
cat /boot/config.txt
aplay -l
aplay -L
amixer -c 0 scontents
amixer -c 1 scontents
amixer -c 2 scontents
BVLabs
Hi, Rern. Any good news about Access Point mode?
@[deleted],
Try:
systemctl enable hostapd
And post result of:
systemctl status hostapd
BVLabs
RuneAudio:~ # systemctl enable hostapd
RuneAudio:~ # systemctl status hostapd
* hostapd.service - Hostapd IEEE 802.11 AP, IEEE 802.1X/WPA/WPA2/EAP/RADIUS Authenticator
Loaded: loaded (/usr/lib/systemd/system/hostapd.service; enabled; vendor preset: disabled)
Drop-In: /etc/systemd/system/hostapd.service.d
`-override.conf
Active: active (running) since Mon 2020-12-14 17:31:41 EET; 3min 33s ago
Main PID: 291 (hostapd)
Tasks: 1 (limit: 2139)
CGroup: /system.slice/hostapd.service
`-291 /usr/bin/hostapd /etc/hostapd/hostapd.conf
Dec 14 17:34:42 runeaudio hostapd[291]: wlan0: AP-STA-CONNECTED f4:60:e2:d6:33:66
Dec 14 17:34:42 runeaudio hostapd[291]: wlan0: STA f4:60:e2:d6:33:66 RADIUS: starting accounting session EBF91D7F3A08DB61
Dec 14 17:34:42 runeaudio hostapd[291]: wlan0: STA f4:60:e2:d6:33:66 WPA: pairwise key handshake completed (RSN)
Dec 14 17:34:46 runeaudio hostapd[291]: wlan0: STA f4:60:e2:d6:33:66 IEEE 802.11: disassociated
Dec 14 17:34:46 runeaudio hostapd[291]: wlan0: AP-STA-DISCONNECTED f4:60:e2:d6:33:66
RuneAudio:~ #
My phone say - Trying to get ip address...
The access point itself is active, you can connect to it, but you cannot get the IP address from the Runeaudio DHCP server's.
BVLabs
When I turn off and then turn on the access point again in Settings / Features, it starts working normally, but before the first reboot.
ray1112
rern wroteray1112 wroteI have Cirrus Logic Audio Card and Raspberry Pi 2.
aplay -l
aplay -L
https://pastebin.com/Ss7htuUG
amonduulii
hi all, running latest rune 120120 version with HiFiBerry Dac+ Pro. All great. Couple issues:
1) I had a breakthrough finally being able to SMB mount or SFTP into my attached USB hard drive running HFSplus (unjournaled is the key). SFTP connection from my Mac laptop to the Raspberry Pi appears to upload the entire MP3 and Rune ingests it into library. But when I get, generally speaking, to tracks 2 or 3 of the album, I am unable to play the entire mp3-- usually first 5-10 seconds, then it skips to the next track in the Queue. The file appears to be the right filesize, but rune refuess to play all the way through.
Anyone else encountered this and have any suggestions? I had heard SFTP or SMB file transfers can be "flaky" but wonder if this is what's meant, or could be something else.
2) Interesting issue with Airplay, though I have "Zero volume" feature set. When I connect with Airplay and adjust volume on my mac, that seems to force a volume setting on Rune that sticks with it, even when I disconnect from Airplay, and then move to Web radio, or something local on Rune. I must reconnect with Airplay, increase the volume to max, disconnect, then the Rune takes on the original "no volume" level.
Keep up the great work and thanks!
BVLabs
rern wrote@[deleted],
Try:
And post result of:
Hi Rern.
I found a solution. It's clumsy, but it definitely works. I don't know what happens, but after that everything works fine.
These are the commands I placed at the end of the startup.sh file:
systemctl disable --now hostapd
ifconfig wlan0 0.0.0.0
netctl stop-all
ifconfig wlan0 192.168.5.1
systemctl restart hostapd
@[deleted],
Please try:
- Remove those added lines in startup.sh
- Run:
sed -i '/Unit/ a\After=startup.service' /etc/systemd/system/hostapd.service.d/override.conf
systemctl daemon-reload
- Reboot
BVLabs
Please try:
- Run:
- Reboot
Did not help, no succsess.
Sonic
Just popped in to thank Rern for restoring the scroll bars in the RPi Browser - Thanks again.
And I find this
bink wrote
rune interface looks nice on my newly built raspberry pi streamer.
Gutting a 'Linn' tuner to build a Pi streamer.
That looks soooo cool!
joe63
hello Rern
I am a new user of your RuneAudio version and I must confess that I find it very interesting and well made, specially as for the graphic layout and effective use of functions. I still haven't run it as my RPI is at the moment out of work but I am trying to get confident with it. Thanks a lot for your huge efforts
So far I have used RuneAudio 0.5b and modified the files config.txt and cmdline.txt according to the tweakings suggested by Frost_dk and Dynobot in the thread
#4301 after that I edited the file orion_optimize.sh to change some parameters related to the sound profiles of the kernel.
Now I am trying to follow the same way in Rune Audio+R e6 but unfortunately I cannot find and edit the file at issue
I wonder if those changes are already set in this version. If not, how is it possible to tweak the sound profiles here?
I am sure that sooner or later someone else will give it a try
Joe
