rern wrote
- Settings > Features > enable
- Click RPi Access Point lable and post the result.
The situation is this: if from the very beginning, the Wi-Fi was turned off and the access point was also turned off, then everything turns on and works. After everything started to work successfully, we reboot, and after it again a bug - we cannot get the IP address.
some boot log:
Dec 11 14:10:42 runeaudio systemd[1]: Started Automatic wireless network connection using netctl profiles.
Dec 11 14:10:42 runeaudio systemd[1]: Reached target Network.
Dec 11 14:10:42 runeaudio audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=netctl-auto@wlan0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Dec 11 14:10:42 runeaudio systemd[1]: Started Hostapd IEEE 802.11 AP, IEEE 802.1X/WPA/WPA2/EAP/RADIUS Authenticator.
Dec 11 14:10:42 runeaudio audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=hostapd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Dec 11 14:10:42 runeaudio systemd[1]: Starting dnsmasq - A lightweight DHCP and caching DNS server...
Dec 11 14:10:42 runeaudio systemd[1]: Starting The PHP FastCGI Process Manager...
Dec 11 14:10:42 runeaudio systemd[1]: Started OpenSSH Daemon.
Dec 11 14:10:42 runeaudio audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=sshd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Dec 11 14:10:42 runeaudio systemd[1]: Starting Permit User Sessions...
Dec 11 14:10:42 runeaudio systemd[1]: Finished Permit User Sessions.
Dec 11 14:10:42 runeaudio audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-user-sessions comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Dec 11 14:10:42 runeaudio systemd[1]: Started Getty on tty1.
Dec 11 14:10:42 runeaudio audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=getty@tty1 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Dec 11 14:10:42 runeaudio systemd[1]: Reached target Login Prompts.
Dec 11 14:10:42 runeaudio hostapd[302]: Configuration file: /etc/hostapd/hostapd.conf
Dec 11 14:10:42 runeaudio hostapd[302]: wlan0: Could not connect to kernel driver
Dec 11 14:10:42 runeaudio hostapd[302]: Using interface wlan0 with hwaddr b8:27:eb:01:5c:6e and ssid "RuneAudio"
Dec 11 14:10:42 runeaudio hostapd[302]: random: Cannot read from /dev/random: Resource temporarily unavailable
Dec 11 14:10:42 runeaudio hostapd[302]: random: Only 0/20 bytes of strong random data available
Dec 11 14:10:42 runeaudio hostapd[302]: random: Not enough entropy pool available for secure operations
Dec 11 14:10:42 runeaudio hostapd[302]: WPA: Not enough entropy in random pool for secure operations - update keys later when the first station connects
Dec 11 14:10:42 runeaudio hostapd[302]: wlan0: interface state UNINITIALIZED->ENABLED
Dec 11 14:10:42 runeaudio hostapd[302]: wlan0: AP-ENABLED
Dec 11 14:10:42 runeaudio systemd-networkd[217]: wlan0: Gained carrier
Dec 11 14:10:42 runeaudio dnsmasq[303]: dnsmasq: syntax check OK.
Dec 11 14:10:42 runeaudio systemd[1]: Started dnsmasq - A lightweight DHCP and caching DNS server.
Dec 11 14:10:42 runeaudio audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=dnsmasq comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Dec 11 14:10:42 runeaudio systemd[1]: Reached target Network is Online.
Dec 11 14:10:42 runeaudio systemd[1]: Reached target Host and Network Name Lookups.
Dec 11 14:10:42 runeaudio kernel: kauditd_printk_skb: 14 callbacks suppressed
Dec 11 14:10:42 runeaudio kernel: audit: type=1130 audit(1607688642.762:26): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=dnsmasq comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Dec 11 14:10:42 runeaudio kernel: audit: type=1130 audit(1607688642.782:27): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=shairport-sync comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Dec 11 14:10:42 runeaudio audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=shairport-sync comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Dec 11 14:10:42 runeaudio systemd[1]: Started Shairport Sync - AirPlay Audio Receiver.
Dec 11 14:10:42 runeaudio audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=upmpdcli comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Dec 11 14:10:42 runeaudio systemd[1]: Started UPnP Renderer front-end to MPD.
Dec 11 14:10:42 runeaudio kernel: audit: type=1130 audit(1607688642.802:28): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=upmpdcli comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Dec 11 14:10:42 runeaudio dnsmasq[308]: started, version 2.82 cachesize 150
Dec 11 14:10:42 runeaudio dnsmasq[308]: compile time options: IPv6 GNU-getopt DBus no-UBus i18n IDN2 DHCP DHCPv6 no-Lua TFTP conntrack ipset auth DNSSEC loop-detect inotify dumpfile
Dec 11 14:10:42 runeaudio dnsmasq[308]: DBus support enabled: connected to system bus
Dec 11 14:10:42 runeaudio dnsmasq[308]: warning: interface wlan0 does not currently exist
Dec 11 14:10:42 runeaudio dnsmasq-dhcp[308]: DHCP, IP range 192.168.5.2 -- 192.168.5.254, lease time 1d
Dec 11 14:10:42 runeaudio dnsmasq[308]: reading /etc/resolv.conf
Dec 11 14:10:42 runeaudio dnsmasq[308]: using nameserver 1.1.1.1#53
Dec 11 14:10:42 runeaudio dnsmasq[308]: using nameserver 9.9.9.10#53
Dec 11 14:10:42 runeaudio dnsmasq[308]: using nameserver 8.8.8.8#53
Dec 11 14:10:42 runeaudio dnsmasq[308]: using nameserver 2606:4700:4700::1111#53
Dec 11 14:10:42 runeaudio dnsmasq[308]: using nameserver 2620:fe::10#53
Dec 11 14:10:42 runeaudio dnsmasq[308]: using nameserver 2001:4860:4860::8888#53
Dec 11 14:10:42 runeaudio dnsmasq[308]: cleared cache
Dec 11 14:10:42 runeaudio avahi-daemon[268]: Server startup complete. Host name is runeaudio.local. Local service cookie is 1585164681.
Dec 11 14:10:42 runeaudio sshd[305]: Server listening on 0.0.0.0 port 22.
