GriffinUcos
Hello, All.
Greatly impressed with this excellent audio solution. I have an old Pi B+ running RuneAudio+Re6 and was able to get virtually everything working straight out of the "box".
I intend to buy a DAC and small amplifier, but in the meantime I wanted to cast the audio to my bluetooth tower across the office. I'm using a bluetooth dongle which works fine on a win 10 machine but I am clearly missing something important as the dongle doesn't seem to be detected. I've connected it direct and via a powered hub to no effect.
Perhaps some kind person can tell this old g*** where to look in the documentation so I can set it up?
Kind regards
Griff.
Ears of Tin
I haven't found anything in the forum so I'm another old g*** looking for the same advice. No trouble sending to Rune from phone/tablet but despite successfully connecting bluetooth speakers and headphones I can't get any sound out of them.
If it's still a work in progress or above my Arch linux skills I can live without. But if a simple toggle or ssh will activate sending BT the old g***'s of the world would appreciate learning of it.
GriffinUcos
Thanks for the moral support EoT, we OGs need to stick together. I looked at some of your other posts which led me to track down /bluetooth main.conf.
Clearly I was over optimistic when I thought BT might be more automated in this version. Having found the conf I'll do some more research and I'll take it from there.
I realise now that I have been "spoilt" on my other Raspi projects.
Take care.
ceejayemm
@EarsofTin
To save searching the whole thread can you summarize how you have got Bluetooth audio working or point me to your original posting on this subject please ?
Chris
dryce
Beelzebassie wroteamonduulii wroteREM GENRE Krautrock
REM DATE 1971
REM DISCID 49113A07
REM COMMENT "ExactAudioCopy v1.0b1"
PERFORMER "Can"
TITLE "Tago Mago"
FILE "01 - Paperhouse.wav" WAVE
TRACK 01 AUDIO
TITLE "Paperhouse"
PERFORMER "Can"
INDEX 01 00:00:00
FILE "02 - Mushroom.wav" WAVE
TRACK 02 AUDIO
TITLE "Mushroom"
PERFORMER "Can"
INDEX 01 00:00:00
FILE "03 - Oh Yeah.wav" WAVE
TRACK 03 AUDIO
TITLE "Oh Yeah"
PERFORMER "Can"
INDEX 01 00:00:00
TRACK 04 AUDIO
TITLE "Halleluhwah"
PERFORMER "Can"
INDEX 00 07:22:15
FILE "04 - Halleluhwah.wav" WAVE
INDEX 01 00:00:00
TRACK 05 AUDIO
TITLE "Aumgn"
PERFORMER "Can"
INDEX 00 18:30:53
FILE "05 - Aumgn.wav" WAVE
INDEX 01 00:00:00
TRACK 06 AUDIO
TITLE "Peking O"
PERFORMER "Can"
INDEX 00 17:29:43
FILE "06 - Peking O.wav" WAVE
INDEX 01 00:00:00
TRACK 07 AUDIO
TITLE "Bring Me Coffee or Tea"
PERFORMER "Can"
INDEX 00 11:35:50
FILE "07 - Bring Me Coffee or Tea.wav" WAVE
INDEX 01 00:00:00
Replace all the "*.wav" extensions to ".flac" in the CUE-sheet.
I have this issue as well. Most of my CDs were backed up with EAC, which creates the cue file automatically upon rip. I compress to flac, but the cue files still have the wav extensions. I have far too many to edit. Is there a way to tell the software to ignore the cue files? Thanks!
Ears of Tin
Chris, re Bluetooth:
I've only used it in phone-to-Rune direction. Go to Settings/System and under On-Board Devices turn Bluetooth on and then reboot. After that "Rune" appears as an available device on my phone. I select Rune on the phone and play podcasts. Works as a sink/receiver very reliably for me.
To send, not so good. Go to Settings/Networks and Bluetooth devices should list after Wifi. Make sure your device (headphones in my case) is in pairing mode and then hit the search icon. Select the device from the newly generated list and pairing commences. I get the green okay light next to the listed device and my device indicates that it is paired. But no sound. Played with mixer and dac settings with no luck.
A New Release After +R e6
Released for public beta testers on
GitHub
Anyone with an extra micro SD card to spare should give it a try. Actually, for the cost of a new card today, everyone should.
ray1112 wroterern wroteray1112 wroteI have Cirrus Logic Audio Card and Raspberry Pi 2.
Version e6 20201201 • RuneAudio
Hardware Raspberry Pi 2 Model B Rev 1.1
Output Device Generic Cirrus Logic WM5102
Q1. How change audio card output (Line out or Headset)? RuneAudio 0.4b have it on MPD page.
Q2. Default mixer is not working (Hardware Volume Control is not working). RuneAudio 0.4b have it working well.
If I change mixer on MPD page to "HPOUT1 Digital" I have error on MPD page:
On RuneAudio 0.4b, post results:
cat /boot/config.txt
aplay -l
aplay -L
amixer -c 0 scontents
amixer -c 1 scontents
amixer -c 2 scontents
https://pastebin.com/Ss7htuUG
Please try the public beta release.
Ears of Tin wrotePerhaps some kind person can tell this old g*** where to look in the documentation so I can set it up?
While Bluetooth is connected, please post results of:
cat /etc/mpd.conf
bluetoothctl info
amixer -D bluealsa
joe63
hello everyone
as i asked in the previous page
joe63 wrotehello Rern
I am a new user of your RuneAudio version and I must confess that I find it very interesting and well made, specially as for the graphic layout and effective use of functions. I still haven't run it as my RPI is at the moment out of work but I am trying to get confident with it. Thanks a lot for your huge efforts
So far I have used RuneAudio 0.5b and modified the files config.txt and cmdline.txt according to the tweakings suggested by Frost_dk and Dynobot in the thread tweaking-the-audio-performance-rpi3-t4301.html, after that I edited the file orion_optimize.sh to change some parameters related to the sound profiles of the kernel.
Now I am trying to follow the same way in Rune Audio+R e6 but unfortunately I cannot find and edit the file at issue
I wonder if those changes are already set in this version. If not, how is it possible to tweak the sound profiles here?
I am sure that sooner or later someone else will give it a try
Joe
it would be interesting to edit the parameters of a sound profile to improve the sound output.
Can anyone tried this tweak? how can I do it by command line please?
thanks a lot in advance
Joe
Ears of Tin
Rern, Here you go:
root@RuneAudio:~ # cat /etc/mpd.conf
bind_to_address "0.0.0.0"
db_file "/srv/http/data/mpd/mpd.db"
replaygain "off"
state_file "/srv/http/data/mpd/mpdstate"
enabled "no"
resampler {
plugin "soxr"
quality "very high"
name "hifiberry-dacplus"
mixer_type "none"
name "Taotronics TT-BH040"
device "bluealsa:DEV=E8:AB:FA:24:14:6E,PROFILE=a2dp"
mixer_type "software"
root@RuneAudio:~ # bluetoothctl info
Device E8:AB:FA:24:14:6E (public)
Alias: Taotronics TT-BH040
Class: 0x00240404
Icon: audio-card
Paired: yes
Trusted: yes
Blocked: no
Connected: yes
LegacyPairing: no
UUID: Headset (00001108-0000-1000-8000-00805f9b34fb)
UUID: Audio Sink (0000110b-0000-1000-8000-00805f9b34fb)
UUID: A/V Remote Control Target (0000110c-0000-1000-8000-00805f9b34fb)
UUID: A/V Remote Control (0000110e-0000-1000-8000-00805f9b34fb)
UUID: Handsfree (0000111e-0000-1000-8000-00805f9b34fb)
root@RuneAudio:~ # amixer -D bluealsa
Simple mixer control 'Taotronics TT-BH040 - A2DP',0
Capabilities: pvolume pswitch
Playback channels: Front Left - Front Right
Limits: Playback 0 - 127
Mono:
Front Left: Playback 93 [73%] [on]
Front Right: Playback 93 [73%] [on]
GriffinUcos
I've edited main.conf with the PID:VID:VER and un-commented the section where needed but the dongle is still not detected.
max_output_buffer_size "32768"
auto_update "yes"
audio_buffer_size "8192"
replaygain "off"
resampler {
plugin "soxr"
quality "custom"
precision "32"
phase_response "50"
passband_end "91.3"
stopband_begin "100"
attenuation "0"
flags "0"
name "On-board - Headphone"
RuneAudio:~ # aplay -l
card 0: Headphones [bcm2835 Headphones], device 0: bcm2835 Headphones [bcm2835 Headphones]
Subdevices: 8/8
Subdevice #0: subdevice #0
Subdevice #1: subdevice #1
Subdevice #2: subdevice #2
Subdevice #3: subdevice #3
Subdevice #4: subdevice #4
Subdevice #5: subdevice #5
Subdevice #6: subdevice #6
Subdevice #7: subdevice #7
Although it works fine in WIN 10 I'll source another. In the meantime I'll try the beta.
ray1112
GriffinUcos
On it now rern, thanks. Not popular at the moment as it is our anniversary!!!
No change, BT dongle still isn't detected. I'l get a new one next week.
Many thanks for this great software.
cmh714
rern wroteA New Release After +R e6
GitHub
Restore didnt seem to work properly for me, but I can do this in my sleep in minutes.....some settings came back properly and many did not. Rebuilding my db now
As always THANKS Rern!
chasolla
good morning
first post from me
rpi3b+ using r1
iquadio dac+ (generic)
just installed - putting wifi settings into boot didn't work for me.
Fortunately the keyboard support is much improved over earlier versions so I put them in easily and quickly.
Restoring my settings from a backup didn't work either but I can remember them all so got them in straight away.
Another old G****
Thanks rern for the great work.
Chas
Mohog
Both e6 and +R (public beta via github) do not allow Airplay to activate on a Raspberry Pi 4.
Clicking on the toggle briefly moves to activated. It will either move back to deactivated immediately or upon returning to the settings screen.
No airplay is available for devices.
Ssoum
I am a new French user. (Sorry for google traductor)
I had great difficulty using the 16x2 GPIO LCD screen.
So as I finally found it, I post the problem here.
The line import RPi.GPIO as GPIO is missing at the top of the 'lcdchar.py' file.
Now things are much better, I continue to test Runeaudio, thank you for all your work.
[EDIT] If it can help other person :
Only for users of 'AUDIOPHONICS I-SABER AMP DAC ES9023' like me, you must also change this line in the same file:
lcd = CharLCD( cols=cols, rows=rows, charmap=charmap, numbering_mode=GPIO.BOARD, pin_rs=15, pin_rw=18, pin_e=16, pins_data=[21, 22, 23, 24], auto_linebreaks=False )
BY
lcd = CharLCD (cols = cols, rows = rows, charmap = charmap, numbering_mode = GPIO.BOARD, pin_rs = 26, pin_e = 24, pins_data = [22, 18, 16, 13], auto_linebreaks = False)
GriffinUcos
Hi rern.
rAudio-1 on Pi B+ connected via wired Lan. Restore does not complete. My "old" BT dongle not detected.
rAudio-1 on Pi Zero W - wifi works on first connection but not subsequently. Wifi file no longer exists on boot. Copying it back onto boot allows it to connect again, but only once. BT does not work.
The BT dongle is probably way outdated, probably a cheap clone Cambridge Silicon Labs - VID-0A12 PID-0001
I've order BT v4.0 and v5.0 dongles and I'll let you know how it goes, if and when they arrive.
Kind regards
Update 20201221
- Fix backup for restore in the public beta.
- There should be no more updates for R e6.
- Please try the public beta or wait a few day for bugs to get fixed.
