Mounting Google Drive
Postby devior » 14 Oct 2018, 11:05
Newbie here. May I ask for anybody who can he help me mount Google Drive, I already followed the steps here: mounting-google-drive-t1321.html. But I get errors on the first step. I am using a Pi B3+.
Thanks in advance.
devior
Re: Mounting Google Drive
Postby hondagx35 » 14 Oct 2018, 11:51
Hi devior,
devior wrote:But I get errors on the first step.
If you like to get help you should post more details.
devior wrote:I am using a Pi B3+.
Please tell us what image you are working on.
In most cases refreshing the packet database helps.
pacman -Sy
pacman -S --force openssl
pacman -S python2 pip2
Postby devior » 14 Oct 2018, 13:16
Thanks for the assistance I really appreciate it. I'm using the image "RuneAudio_0.4_20180629_SC_Pi3B_Plus_v3_tml3nr".
The second command which is "pacman -S python2 pip2" it returned an error "pacman -S python2 pip2
pacman: error while loading shared libraries: libcrypto.so.1.0.0: cannot open shared object file: No such file or directory"
Thanks is advance!
devior
Postby hondagx35 » 14 Oct 2018, 16:05
you can try:
pacman -Sy openssl pacman wpa_supplicant hostapd
but it may break the system, so be warned.
See also here.
Postby devior » 16 Oct 2018, 16:36
It still has errors when executing "pacman -S python2 pip2" --- error: target not found: pip2
devior
Postby devior » 16 Oct 2018, 18:09
Should I use the Pi3B instead of the Pi3 B+? I just want to mount the Google Drive to update the music library automatically. Thanks
devior
Postby hondagx35 » 16 Oct 2018, 18:18
I have no device available at the moment for testing.
You can try:
pacman -S python2-pip
Postby popov » 16 Oct 2018, 18:19
Could you try
pacman -Sy python2-pip
Regards
Envoyé de mon iPad en utilisant Tapatalk
popov
Postby devior » 18 Oct 2018, 10:44
I'm having problems after executing the commands/syntax that you gave me guys. Do you think I should get just the Pi3 B device? Thanks in advance.
devior
Users browsing this forum: Bing [Bot], Google [Bot] and 4 guests
