DSD tags?
DSD tags?
Postby guyb » 09 Sep 2015, 07:08
Hey all,
Does RuneAudio support tags in DSD files?
I am using RuneAudio as a DLNA renderer and use my Synology NAS and AudioStation to 'send' audio to RuneAudio.
I get full tag support for FLAC and MP3 and so on.
I have attached an image show the info displayed for DSD files
GuyImage
guyb
Re: DSD tags?
Postby fongalv » 10 Sep 2015, 08:01
Hi, just wanted to chime in...I'm running Runeaudio and it does display my dsf tags, so it's definitely supported. I disabled dlna and mounted the network drive directly within runeaudio though.
fongalv
DSD tags?
Postby guyb » 10 Sep 2015, 08:04
So it must be a DLNA thing!
The question now is - is this a Rune Audio thing or is it my Synology NAS?
How would one go about trying to find out?
Guy
guyb
Re: DSD tags?
Postby fongalv » 11 Sep 2015, 03:25
Sorry man, I'm kinda new to all these and not very well versed with DLNA, so won't be able to help much.
I'm running Runeaudio on a Rpi2 though, how about you? I previously tried DLNA streaming via desktop JRiver and found the remote control via app extremely clunky and laggy. After which I mounted the harddisk directly as a network source and controlled it via WebUI and found it a lot more responsive, hence i'm sticking to this setup.
I believe this also enables bit perfect output to an external USB DAC(which is what my setup does),I'm not sure if DLNA supports the way I want to setup my "listening post" system.
fongalv
