Switch to mpg123 decoder for mp3
Postby Midnight » 10 Mar 2014, 22:40
I'd suggest to switch to mpg123 as default decoder for mp3 files. The libmad decoder produces some low level noise, that can be heard (especially with good headphones) in silent passages of a track (or between two tracks). It's also easy to reproduce if you activate software mixer and turn down mpd volume.
Steps to reproduce the noise with libmad:
1. turn down mpd volume (software mixer)
2. turn up volume of your amp
3. play a mp3
With mpg123 or other file formats (FLAC, Vorbis) there is absolutely no noise. I've tested this on runeaudio and also on my PC (with two different output devices).
Also mpg123 is still activley developed while libmad's last version dates to 2004.
Midnight
Moderator
Re: Switch to mpg123 decoder for mp3
Postby FauDrei » 11 Mar 2014, 12:28
How you do this?
Should mpd be recompiled or are there other ways to use mpg123 for mp3 decoding?
FauDrei
Postby Midnight » 11 Mar 2014, 12:34
Midnight
Moderator
Postby ACX » 11 Mar 2014, 15:58
Hi Midnight, as always thank you for the hint. Yesterday night we recompiled MPD with mpg123 support, so tonight we will give it a try.
Curiously, while experimenting with different kernel versions (I'm currently using a custom build of 3.12-7), I had troubles with MP3 reproduction over USB, but NOT with FLAC, and I still haven't found the cause behind that. So I want to see if this decoder introduces improvements on that front too.
Postby FauDrei » 12 Mar 2014, 11:13
FauDrei
Postby Midnight » 12 Mar 2014, 11:35
AFAIK all decoder plugins are enabled by default. But you have to disable mad, because it has a higher priority than mpg123.
Midnight
Moderator
