wi-fi problem
wi-fi problem
Postby domisol » 27 May 2015, 14:56
I use runeaudio with a wired connection, but wanted to test wireless in the case I would need it for a secondary installation.
Here is my issue :
As shown in the screen capture, It says it connects to wi-fi profile, but the wifi profile list is empty, even I attempted to create one.
SSID list is shown but at the end I can't success in connecting to network.
Using Rapsberry PI2 with TL-WN722N.
Jean-David
wifi rune.jpg (99.28 KiB) Viewed 2067 times
domisol
Re: wi-fi problem
Postby hondagx35 » 27 May 2015, 22:34
Hi Jean-Davis,
most often problems with wifi belong to bad power supply.
If possible try to use a powered usb hub for testing.
Re: wi-fi problem
Postby domisol » 27 May 2015, 22:40
domisol
Return to Bug report
