Access saved plaaylists from the library page.
Postby Aswell » 29 Mar 2015, 17:09
I have some music on a USB Memory and some in the SD card. I create play-lists but it seems I can only access them from the device storing the music have used for the playlist. I think it would be good if there was a 'Playlist' section in the Library page which give you access to any saved playlist?
Brian
Aswell
Re: Access saved plaaylists from the library page.
Postby ACX » 29 Mar 2015, 18:40
Hi Aswell,
in the left bottom of the Queue panel you can find the "Manage playlists" which, although it still has a very simple implementation, does the job.
Postby Aswell » 29 Mar 2015, 20:26
OK, yes, I suppose you can do it via the playlist tab, which I suppose makes sense. My mind suggests it would be nice to access the playlists from the library tab....
Aswell
Postby 190e2.3 » 29 Apr 2015, 14:16
Sorry, my english isn`t very well. I read in your post about playing music/mp3`s from the sd-card (of the os i think). How can i do this?
Thank for your answers.
190e2.3
Postby hondagx35 » 29 Apr 2015, 20:43
Postby 190e2.3 » 01 May 2015, 01:18
It works very well.
Thank you Frank
190e2.3
Postby anadigi » 01 May 2015, 02:57
I have followed your instruction to delete the partition but when I reboot, it will not work anymore and how can I continue to do the next step resizing the partition?
anadigi
Postby hondagx35 » 01 May 2015, 17:37
Postby anadigi » 01 May 2015, 17:56
Thanks Frank!
I did exactly from you post but once I rebooted and tried to re-size. It won't boot.
If I delete the partition, then all the existing files will be gone! Just wondering how the files can keep in this partition?
anadigi
Users browsing this forum: No registered users and 25 guests
