API endpoints
API endpoints
Postby Grins » 27 Feb 2014, 16:25
Hey,
Is there a rest api for the rune audio service? I was thinking of using a hubot chat bot to control the playback from the runeaudio device.
Thanks, :mrgreen:
Grins
Re: API endpoints
Postby ACX » 27 Feb 2014, 17:41
Hi Grins, as RuneAudio uses at its heart, it could be simpler to use (TCP commands on the 6600 port), controlling the daemon directly without having to go through our UI. RuneUI is de facto an MPD client, in addition to be a a system configuration UI.
Re: API endpoints
Postby ACX » 28 Feb 2014, 17:14
I forgot to say that you can also use this urls to control the playback:
http://runeaudio.local/command/?cmd=CMD
where CMD is a command from MPD playback command reference:
http://www.musicpd.org/doc/protocol/ch03s03.html
Re: API endpoints
Postby Grins » 03 Mar 2014, 17:16
Sweet I will check that out. Thanks for the quick reply.
Grins
Re: API endpoints
Postby tatoosh » 01 Feb 2015, 18:45
Is there an API for developing custom commands?
I want to implement sleep mode, so i need a 10min delay before mpc stop will be send.
P
tatoosh
Re: API endpoints
Postby ACX » 01 Feb 2015, 20:29
Re: API endpoints
Postby tatoosh » 01 Feb 2015, 21:08
thanks. untill there is an API i will at custom buttons with jquery in runeui.JS
tatoosh
