Balance, Loudness, Equalizer
Postby tinue » 22 Mar 2015, 18:07
I think most people use their Runeaudio connected to an amplifier. So they usually have balance etc. available.
My Runeaudio-powered Raspberry Pi however uses a Hifiberry Amp, connected directly to speakers. Unfortunately, I can't place the speakers perfectly for my sitting position, so I would need to shift the volume a bit to the left speaker.
I have read that there are plans to eventually include an equalizer.
Are there also plans for a simple balance regulator?
Thanks! Martin
P.S. I use a Bowers & Wilkins Z2 in my home office, and over this weekend made the first serious tests with RuneAudio / Raspberry / Hifiberry Digi. The Z2 is supposed to be good, and did cost a fair amount of money. But RuneAudio just blows it away. Not only does it offer almost the same set of features (including AirPlay, excluding direct playback from a USB attached iPhone), but it sounds a lot better, and it is less expensive. Thanks for the great work!
tinue
Re: Balance, Loudness, Equalizer
Postby ACX » 23 Mar 2015, 01:15
Postby tinue » 23 Mar 2015, 18:50
Alsamixer
Bildschirmfoto 2015-03-23 um 18.47.46.png (12.04 KiB) Viewed 5260 times
tinue
Postby BorGreiner » 25 Mar 2015, 08:49
That is something I'd like to see too, my amplifier just doesn't have remote and at least balance would be nice to have and maybe not hard to implement. :)
BorGreiner
Postby whoozwah » 23 Aug 2015, 17:48
whoozwah
Postby Mat » 27 Aug 2015, 09:17
Hi, I use RPI with a HifiBerry digi+ card. So I use optical output to my active speakers (bit perfect).
I thought that there is no option for alsamixer when using digi+ (not DAC) card.
Since I miss bass when playing at low volumes I would like to have some kind of "loudness" button. https://en.wikipedia.org/wiki/Loudness_compensation
Is there any (at least theoretical) option to affect sound before signal goes to HiFiBerry? Is there already some kind of option on runeaudio for low volume listening?
Mat
