netjack.
netjack.
Postby mashman » 03 Mar 2015, 09:03
Hey,
I had a thought. What about running as a device and then having another jack client on a rPi in another room?
Alternatively, shairport as an output device and then another rune installation recieving it.
I can imagine having one server and a couple of clients all controlled simply by the device outputs configured in the .asoundrc file. The advantage to this is that it would suit other mpd clients that are able to control the sound device output.
mm
mashman
Re: netjack.
Postby Orion » 04 Mar 2015, 18:19
Hi mashman,
we prefer the netjack route. I've also had your same idea. This is the reason why is there almost from day 1 of RuneAudio.
Think about MPD as a sort fo "Hydra" where the body is the Master player and the heads are the client players controlled by the Master.
I think that Jack is the way. A very powerful stack built for professional. The only thing that is missing here at the moment, is the time to develop this solution. Do you want to contribute to this task? You'd be welcome.
Ciao.
Simone.
- Embedded Hi-Fi music player
Orion
Re: netjack.
Postby g33kdad » 31 Mar 2016, 01:07
So, I would love this functionality as it has been discussed. I don't have any coding skills nor am i familiar with Jack enough to get it to work. However, if you have a bounty program, I would be happy to contribute.
Thanks and I love Rune Audio!
Matt
@sahg33kdad
Version: release version: 0.4 (build: beta-20141216)
Hardware: RasberryPi 2 B+, usb audio card, bookshelf stereo system
Sources: NAS and various webradios from Soma.fm and Capitol Public Radio (sacramento, ca)
g33kdad
Re: netjack.
Postby hondagx35 » 31 Mar 2016, 18:04
Hi g33kdad,
what is the feature you like to have? Multiroom?
I'm also interested in this and trying to use for it.
See also .
Features i would like:
- multiple RuneAudio devices
- each one can act as standalone player
- one is also a master device
- you can switch all others to slave mode
- they will reflect the status from master device
- they can be used to control the master device
- each one can control only its own volume
- no idea about multizone yet
Users browsing this forum: No registered users and 48 guests
