by anfuca » 08 Jul 2015, 20:29
			Hi, first of all, congratulations for this awesome work.
I'm very interested in the crossfade function. I have implemented as you've said but I'm getting some "troubles".
I've setted to 15 sec using the service that @bleu34 posted.
I start RuneAudio and check the crossfade time. It shows me 15. Ok.
But then, when I play music, some songs aren't crossfaded at all, and others are crossfaded but not the way that it should be, the crossfade duration is less than the 15s I've setted.
Have any of you noticed this?
Maybe is a MPD issue?
P.D: Ok. Solved. It's a MPD configuration thing about buffers size. Explained here:
Once buffer size increased, it works like a charm!
