Volume low with 0.2 beta
Postby floric » 03 Feb 2014, 22:24
I am using the runeaudio 0.2 beta on a raspberry pi. For the output I use the miniStreamer (http://www.minidsp.com/products/usb-aud ... nistreamer) which is a usb audio to spdif interface. The spdif is fed into my dac, as all my digital sources. My flac files are on a local usb disc.
The setup works very well and gives good sound, no cracks or anything, at least with 44.1kHz files.
But: the volume is very low, I think more than 6dB lower than e.g. the identical hardware setup using other OS/Software Packages (e.g. Volumio, Openelec) and than my other digital sources.
As it is not a hardware problem - the hardware works perfectly, the volume must be reduced anywhere in the software.
Any hints, where this might be?
Best regards
Floric
floric
Re: Volume low with 0.2 beta
Postby floric » 03 Feb 2014, 22:34
...what I forgot to mention:
The behaviour is the same, no matter if I disable the volume control (the GUI shows 100) or if I enable the volume control and set it to 100. The volume control works if enabled.
Kind regards
Floric
floric
Postby ACX » 03 Feb 2014, 22:41
Hi floric, which type of volume control have you tried? The hardware one or the software one? You could have the first one set to a lower value, so the software one could only reach the maximum level of the hardware one.
You can also check it via alsamixer command from terminal.
Postby floric » 04 Feb 2014, 01:06
Hi ACX,
thank you for the quick reply.
I used the software volume control.
alsamixer shows that the PCM-Volume is set to -20dB. If I set the volume control to hardware, the display shows 64. If I turn it up, the volume increases (who wonders) and the display in alsamixer too.
But after a reboot these settings are gone and low again.
Is there a config file where I can set the hardware-volume setting to 100 resp. 0dB?
Regards
Floric
floric
Postby floric » 16 Feb 2014, 17:22
now I get some unpredictable behaviour. Just to find out why: Does the UI store the Volume settings anywhrere? Is this information read on startup?
Regards
Floric
floric
Postby darpmalone » 24 Jan 2015, 16:41
darpmalone
Return to Bug report
