Driver for Audiophonics ESS9038Q2M
Re: Driver for Audiophonics ESS9038Q2M
Postby Nocolo » 06 May 2019, 11:28
Nocolo
Postby janui » 06 May 2019, 13:08
Postby Nocolo » 06 May 2019, 16:03
Hi Janui,
I did an ugly thing but it seems to work :
I duplicate /usr/lib/libreadline.so.7 into /usr/lib/libreadline.so.8
I also modify the source file "i-sabre-q2m.c" :
-> replace "snd_soc_component_read32" by "snd_soc_read" and other minor modifications (I will describe them in another post if I succeed...)
By doing these modifications, I compile and generate the files .ko (i-sabre-codec.ko and i-sabre-q2m.ko) and I generate the .dtbo file (i-sabre-q2m.dtbo).
Big step ahead !!!
A that point, I need to integrate that driver into Runeaudio...
And for that i need your help.
Many thanks
Nocolo
Nocolo
Postby janui » 06 May 2019, 18:48
Postby Nocolo » 07 May 2019, 00:45
Nocolo
Postby janui » 07 May 2019, 16:07
Hi Nocolo,
Have you tried using it? Maybe it will just work even if depmod seems to have problems.
Postby AlleyCat » 03 Apr 2020, 14:38
Hi there,
I am also looking for a Rune build that supports the AUDIOPHONICS DAC I-Sabre ES9038Q2M board. I am not going to attempt the rebuild or compile drivers. Is there a build of Rune that has these drivers already compiled and ready to use?
Thanks,
Alley Cat
AlleyCat
Postby Nocolo » 25 Apr 2020, 15:17
A few months ago I adapted a driver for the Audiophonics board based on ESS9038Q2M component for the Raspdac Mini product. I started from the version 0.5b of Janui and I generated an image which is available on the Audiophonics website :
You may download the image directly from :
Hope it will help.
Nocolo
Nocolo
Users browsing this forum: Bing [Bot] and 0 guests
