Need help on GUI update
Postby mica » 03 Dec 2017, 00:37
mica
Re: Need help on GUI update
Postby janui » 03 Dec 2017, 12:36
Postby hondagx35 » 03 Dec 2017, 13:23
Hi mica.
in addition to januis description:
The backend (MPD) and the frontend (browser) communicate through web sockets see "/srv/httpassets/js/runeui.js".
With such a small screen I wouldn't go the browser route.
I would write a python script and control the backend with the library.
Postby mica » 03 Dec 2017, 22:40
Thank you both,
I have changed from a Hifiberry DAC to a AMP and there I miss a simple method to change the volume.
This was the reason to add some small display to the RPI to change the volume locally without the PC / Laptop etc.
It is not intended to have the full features of the RuneUI on the small display, as this will make definitely no sense.
The picture gives you an impression on what I am trying to do:
However there are further things, which I think of:
- Select one of (up to 6 or so) pre-defined radio stations.
- Select a playlist.
But back to the basics (one step after the other :roll:).
I see that the values are updated by a pushstream method from the server side (thank you Frank for pointing to the right direction). I assume that I need to put some code inside the function updateGUI in runeui.js to update my own volume display.
Michael
runeaudio_ (1).png (39.2 KiB) Viewed 1613 times
mica
