UI stops working after several hours
Postby uli » 17 Jun 2016, 18:50
uli
Re: UI stops working after several hours
Postby hondagx35 » 18 Jun 2016, 09:47
Postby uli » 18 Jun 2016, 11:23
thanks for the reply! I guess I'll remove the logrotate package then. Shouldn't the permissions of /var/log/runeaude be rwxr-xr-x anyway?
I think I've tried getting to the UI through IP without success. But I have to try again next time, sorry...
Note that I'm running kernel 4.4 (Updated following )
Also I'm using the RuneAudio in its origin/dev version (updated via git pull in /var/www/).
Let me know if I can help with any other tests or logs...
Thanks,
Uli
uli
Postby uli » 27 Jun 2016, 22:20
uli
Postby magic-music » 27 Jan 2017, 08:46
Bump.
I'm a new RuneAudio user. After trying a QED uPlay for 6 months and being unhappy with it, I read good things about RuneAudio, and so far I love it - with the exception of this bug.
I have a brand new Raspberry Pi 3. A fresh install of RuneAudio, no tweaks or changes.
I connect the Pi to my network switch, which includes my NAS. It found the music there and streams no problem. I also added 9 radio station streams, they also play back no problem.
However, after a few hours without using it, the UI is unresponsive. The Android app won't connect, and I can't connect via IP. If I ping the IP address I get no response, although my router shows the Pi is still connected. Every morning when I get up,I have to power down the Pi and reboot it, and the same when I get in from work every evening. This literally happens twice a day, every day. I tried doing a git pull from the dev settings to see if that update would help, but no improvement. The PSU I'm using is an ex iPad one, 5v 2a.
I'd love to see this bug ironed out, I really don't want to have to buy a timeswitch just to power the Pi down twice a day!
Just to confirm once more, this is an unaltered, untweaked version of RuneAudio. I downloaded it, used the recommended software to extract the image to the sd card, and plugged it in.
Has anyone got anywhere in tracking this down?
magic-music
Postby hondagx35 » 27 Jan 2017, 11:38
Hi magic-music,
the problem seems to be the Android app and not Rune.
post19185.html
Postby KrzyszB » 28 Jan 2017, 10:33
First: sorry for my English, but I hope you understand me :)
I use RPi3 and RuneAudio for 3 months and I had the same problem when the WiFi card was set to DHCP.
When do I set the IP address directly in RuneUI problems disappeared. Perhaps a problem with my router?
RuneAudio working non stop, but once a week (or two) I do restart - prophylactically :)
I updated to the latest version of Linux and RuneUI too.
The only modification I made: setting samba to my needs.
I used before Volumio, but RuneAudio is much better: appearance and stability.
KrzyszB
KrzyszB
Postby magic-music » 28 Jan 2017, 12:14
How weird! I guess it will be interesting to operate Rune from the phone using Chrome instead and see if that makes a difference!
Cheers
Adam
magic-music
Return to Bug report
Users browsing this forum: No registered users and 42 guests
