Cubietruck
Cubietruck
Postby TBM » 05 Mar 2014, 07:32
Would have been more than nice if you could get Cubietruck device on the list of supported devices.
It also has I2S up and running now for audio..: http://www.cubieforums.com/index.php?topic=1081.0
Cheers
TBM
Re: Cubietruck
Postby ACX » 05 Mar 2014, 12:45
Hi TBM, we tried to contact Cubietech multiple times but with no response. So we left it aside for a while, focusing on the other platforms.
Anyway it's a board that we'd love to support in the future.
Re: Cubietruck
Postby TBM » 05 Mar 2014, 13:32
Ok! :-)
TBM
Re: Cubietruck
Postby clsidx » 18 Apr 2014, 13:18
Always no news from designer's cubitruck
clsidx
Re: Cubietruck
Postby wout » 08 May 2014, 21:02
I have a Cubietruck lying around. Would be nice if I could use it to run RuneAudio!
wout
Re: Cubietruck
Postby Midnight » 18 Jul 2014, 12:56
Midnight
Moderator
Re: Cubietruck
Postby ACX » 18 Jul 2014, 13:36
Re: Cubietruck
Postby Midnight » 18 Jul 2014, 14:08
I don't know anything about the Arch Linux repository system, but I guess custom packages (e.g. recompiled mpd) can be installed via custom repositories. Just create a repository for different architectures (many boards share the same architecture) like armv7hf, armv5, i686, x86_64 and put in the recompiled packages. These custom repositories need to have an higher priority than the default repositories. The install script then just has to detect which architecture it is running on an chose the correct repo to add.
If custom kernels are needed (e.g. to add i2s audio support) it is a lot more complex because in opposite to packages each board needs an own kernel.
Midnight
Moderator
Re: Cubietruck
Postby ACX » 18 Jul 2014, 14:26
That's another thing we had in mind to do, we started to ourselves but at the end we hadn't the time to put it in practice.
Could you help us with that to speed up things?
Re: Cubietruck
Postby hondagx35 » 12 Sep 2014, 00:46
Users browsing this forum: No registered users and 65 guests
