Feature Request: Player Name on UI home screen
Postby jcoman » 01 Apr 2016, 21:48
I wanted to suggest that there be a player name that is displayed on the UI home screen/header bar. I currently have 4 different pi's running Rune, and when I have the default UI up, there is no way to tell which player I'm talking to (I have the UI page added to homescreen from Chrome on Android, so none of the browser chrome (i.e., address bar) is visible).
I did manage to work around it by modifying one of the files (i think it was index.html/php, but it was a while ago) to put the player name in the upper left corner. However, it doesn't work very well on phone screens (or other screens that are too narrow) because it gets shoved behind the RuneAudio logo (I couldn't figure out how the style/CSS worked on that).
I think it might be useful for users to be able to modify that text from the settings menu (like where you set the player name), so that it's easy to tell which player you are currently talking to.
jcoman
Re: Feature Request: Player Name on UI home screen
Postby hondagx35 » 03 Apr 2016, 01:16
Postby ACX » 09 Apr 2016, 01:44
Hi jcoman,
As you are using Android you could use the to easily switch between multiple players.
Postby jcoman » 09 Apr 2016, 02:52
Thanks ACX, I'll give that a try.
edit: I tried the Android Remote Control, and (after adding in the service as suggested in the install instructions) it worked perfectly. It still doesn't show the player name without pulling up the app's menu, so I'm going to try Frank's suggestion.
edit: I tried Frank's Idea, and it worked perfectly. I just put in the player name directly because it was different than the hostname that I use to identify the device on the network. Now the only thing that's missing is the lockscreen controls :mrgreen:
Thanks for all your hard work guys! #ThumbsUp!
jcoman
