[PROPOSAL]: Alarm Clock
Re: [PROPOSAL]: Alarm Clock
Postby JB314 » 23 Feb 2015, 10:44
I don't think there is advantage over systemd, it's just a different way to do that.
Probably systemd brings some new features but I used to use crond, so... :D
JB314
Postby SlF » 07 Jan 2016, 20:13
SlF
Postby JB314 » 08 Jan 2016, 10:07
Hi SlF,
You can check the content of the files /var/www/command/wakeup and /var/www/command/wakeup.cron if there is something inside.
The 1st one stores the data for the WebUI and the 2nd one stores the data for cron job.
If they are empty, that means the data are not correctly submitted or saved. You can check the owner and group and verify the write access on both files. (commands for that are chown and chmod)
You can also check contab items to see if there is something pending : crontab -l
If everything is okay here, it can be the rights on the play and stop files. Just check the owner and group and verify the exec access is on.
Let me know.
JB
Edit : If you are running the dev branch on your system, you can also check the pull request i've made on top of it, which adds alarmclock, podcasts player and a "sleep mode" : https://github.com/RuneAudio/RuneUI/pull/67.
It could be applied also on the master branch but the source code may be a little bit different.
JB314
Postby SlF » 11 Jan 2016, 13:51
Thanks for your help, I made play and stop files +x and now everthing is working :-)
SlF
Postby Pilou007 » 28 Jan 2016, 15:41
Pilou007
Postby SlF » 31 Jan 2016, 12:25
You are lucky ... in the web UI nothing appears in the menu ...
What Can I do?
________________________
Did you reboot or at least restarted php? Did you copy ALL the file? Did you edit the array list? The array list is important to give you "Alarm Clock" in the upper right menu.
SlF
Postby SlF » 02 Feb 2016, 16:42
SlF
Postby Pilou007 » 07 Feb 2016, 19:44
Pilou007
Postby SlF » 10 Feb 2016, 12:44
SlF
Postby Pilou007 » 16 Feb 2016, 16:39
Hi Sif
I tried another time with a new SD card :
[root@runeaudio ~]# cd /boot
[root@runeaudio boot]# tar -xvf RuneAudio-Wakeup.tar
var/www/assets/js/runeui.js
var/www/assets/js/runeui.min.js
var/www/assets/js/vendor/jquery.clockpicker.min.js
var/www/assets/js/vendor/jquery.bootstrap-touchspin.min.js
var/www/assets/css/jquery.clockpicker.min.css
var/www/assets/css/jquery.bootstrap-touchspin.min.css
var/www/command/play
tar: var/www/command/play: Cannot change ownership to uid 33, gid 33: Operation not permitted
var/www/command/stop
tar: var/www/command/stop: Cannot change ownership to uid 33, gid 33: Operation not permitted
var/www/app/wakeup_ctl.php
var/www/app/templates/wakeup.php
var/www/app/templates/header.php
var/www/app/templates/footer.php
tar: Exiting with failure status due to previous errors
you can see two errors in the files copied. why ???
i have double checked the $controllers array i have add a , just after tun as you can see :
'settings',
'sources',
'tun',
'wakeup'
cronie is installed and enable...
I really need help as I am not very comfortable with all this stuff (nor in english ;-) )
thanks for your help
Pilou007
Pilou007
