Hi all here,
i have got a hifiberry DAC from Daniel in december and it worked very well in my RaspyFi installation with the rPi-Update described. But then i discovered the runeaudio implementation. Because it is based on Archlinux and i tried Archlinux before in all my computers and its for me the best Linux distro ever, i wanted to have the runeaudio immediately.
Unfortunately the I2S-support is missing so far.
I decided to get it for my own and followed the kernel compilation guide on "
http://elinux.org/RPi_Kernel_Compilation".
I downloaded the source rpi-3.12-y and activated the appropriate kernel modules.
It was not a short way until i succeded in getting the hifiberry work, but finally it did.
When the kernel is changed the problem is that i dont know in which script i should load the modules.
I placed a file "/etc/modules-load.d/rasperrypi.conf" to load the modules
snd_soc_bcm2708_i2s
snd_pcm_dmaengine
snd_soc_pcm5102a
snd_soc_hifiberry_dac
But there the load time is to early and the modules don't load properly.
When i do the modules load after the boot manually it loads correct and voila the hifiberry works.
Greets
Juergen
P.S.: to Daniel (hifiberry) : the hifiberry sounds very good even with the normal rpi cheapy psu.
