rern wroteKernel 5.4.77
- Available in today's updated image files, not by Addons update.
- No needs for any current R+R e6 to reflash the SD cards unless for the character LCD feature or driver issues.
- Manually update with pacman -Syu is OK except RPi 1 and Zero that need onboard audio.
Done that last thing, no audio possible
RuneAudioI:~ # mpc play
http://playerservices.streamtheworld.com/api/livestream-redirect/JOE_TOP2000.mp3
[paused] #2/2 0:00/0:00 (0%)
volume: n/a repeat: off random: off single: off consume: off
ERROR: Failed to open "rpi-dac" (alsa); Failed to open ALSA device "hw:0,0": Device or resource busy
On RPi3b...
Even rune rebuild (create-rune.sh) to no avail.
Mpd page doesn't allow audio buffer change (only true or false is written in mpd.conf)
LCD char display only uses i2c even though GUI indicates gpio possible. Needless to say nothing happens on connected and working (Pydpiper) display.
Bug for me not changing system time, audio i2s change is not reflected on system page, nor is change written in /srv/http/data/system/ files.... still present.
Luckily boot config remains untouched as well
No luck in past week to get snapserver/snapclient to run in R+Re6 systemchain.
Not all is well....
LCD char looks promising, though pinout should be adaptable.... My dac amp has the hardware on board but probably different pins....
A8
