rern wroteUpdate 20191008
- Fix - Switches in setting pages not responding.
- Fix - NAS mount notification bug.
- Allow consume mode while others still on.
Thanks Rern
NAS mount works again
Switches work again
BUT ....
the timezone always shows the first option of the list (Africa/Abijan)
luckily the system time is acutally still correct (system time is local time) (Europe/Brussels in my case)
an old bug seems to creep up again : changing the time zone 'scrambles' the I²S DAC settings to usually X10 DAC and it's impossible to set it back to my working config. Upon close of the system page, I get the reboot popup.
Almost every reboot has to be a cold boot, a warm boot just hangs after mounting/starting the USB peripeherals
After the boot, I don't have I²S output on the MPD page and no sound, analog output instead
If I go back to system page, I see that my dac is selected correctly yet the relevant section of the /boot/config.txt shows differently
## RuneAudio HDMI & 3,5mm jack
dtparam=audio=on
## RuneAudio I2S-Settings
#dtoverlay=none
This is after the reboot, I actually checked : before the boot it has audio=off and dtoverlay=none
So I said no mas and manually changed this to
dtparam=audio=off
dtoverlay=rpi-dac
and after reboot, everything appears to be fine (I get sound, I²S in MPD page)
No status info at the top of the system page
The switches do toggle on the system page but if I close the page and reopen it, all toggles are set to off again...
It seems that the system page has issues getting/setting the correct data
Could someone who has RPI2 confirm this if possible
A8
