Stablgr,
I think you might need display_rotate=2 for HDMI. I am pretty sure that lcd_rotate only affects the lcd port.
stablgr
Doh! That makes so much more sense. Thanks R101. Works like a charm now.
Update 20200120
Fixed - Auto update in MPD settings
Fixed - Bluetooth, Wi-Fi and Browser on RPi in System settings
Fixed - Add 1st Webradio not show unless refresh
Improved - Playback interface now responses without delay
klassikmann
rern wroteUpdate 20200120
Thank you for the update. And by the way: Happy New Year.
klassikmann
chrisryburn
After trying an early version on my Raspberry Pi 2B with my mojo DAC, which worked well. Subsequent versions didn't work well, so I gave up and used another product.
I've just tried again, downloading, running update successfully, but finding it won't read my USB drive. It finds it, but the light is red and it won't mount.
/mnt/MPD/USB//dev/sda2 contains a hfsplus file system labelled 'Music'.
Drive read fine by 0.5 version
Appreciate any help
eggshell
I have RuneAudio+Re2, MoodeAudio and Volumio on three different microSD cards. I use a Pi3B+ and Allo Boss DAC. I have to say that I always come back to Rune as it sounds the best. The difference is subtle, but I find myself tapping my foot to the music way more often when using Rune.
I also like the interface the best. Great job Rern. Thanks for your efforts.
There is one thing that I was hoping to get some help with. Is there a way for the MPD scan to ignore the @eaDir files? It makes everything take longer and the CoverArt scan gets bogged down with them as well. I am using a Synology NAS for my music storage.
Andreas
klassikmann
eggshell wroteThere is one thing that I was hoping to get some help with. Is there a way for the MPD scan to ignore the @eaDir files? It makes everything take longer and the CoverArt scan gets bogged down with them as well.
Two answers:
- From the mpd user manual (https://www.musicpd.org/doc/html/user.html):
To exclude a file from the update, create a file called .mpdignore in its parent directory. Each line of that file may contain a list of shell wildcards. Matching files in the current directory and all subdirectories are excluded.
- Search for ".mpdignore" here in the forum.
klassikmann
AndyF
... and an additional info - folders can be excluded via context-menu at library on Re2 (it creates an .mpdignore-file).
Andy
klassikmann
AndyF wrote... and an additional info - folders can be excluded via context-menu at library on Re2 (it creates an .mpdignore-file).
Andy
Doh!
I overlooked the simplest solution für RA+Re2.
klassikmann
Updated image files
Image files in the 1st post were updated with:
- RuneAudio+R e2 20200120 (by Addons)
- Latest packages (by pacman -Syu)
- HFS+ support (by hfsprogs package)
chrisryburn wrote
... It finds it, but the light is red and it won't mount.
Try the updated image file.
eggshell
Thanks for the tips on ignoring the @eaDir directories.
One more thing, I recently switched my NAS shares from NFS to SMB and now I can't bookmark the folders. I can select the bookmark option when long clicking a directory, but they don't show up in the library.
Any ideas?
Thanks,
Andreas
Hi Andreas,
Try update via Addons again.
proteus
Hi all, did someone get an 3.5" LCD working with Re2? Lcd works fine on the official version and i tried to follow the same steps but with no success.
Paul
Hi rern,
I cannot create a Library bookmark for the USB stick or for any files on it. Is this a permissions problem?
J4K
Hello Everyone,
I Have RuneAudio+R e2 fully updated on a rpi3b, fresh install. Connected via WiFi. everything works great and I have Music Playing. But I cannot map to the powered ssd drive that is attached to the pi. Running win 10, media streaming options can see runeaudio.
Everything else connected shows when mapping, just not RuneAudio.
Also is there a DEV Page available like runeaudio 4?
Thanyou for reading.
J
eggshell
Hi Rern,
Just updated to latest. No errors on update. Rebooted, but still no bookmarks. There is no confirmation banner that shows when adding a bookmark, and of course no bookmark in the library.
Otherwise, I think you have things pretty dialled in.
Andreas
@[deleted] and Andreas,
Add bookmark - Fixed with the update.
@[deleted],
- Settings > System > File sharing - on
- No DEV page in R+R e2. What do you want to do?
Thanks rern, the bookmarks are working now.
The addons update process does lose the Color setting, though.
klassikmann
R101 wroteThe addons update process does lose the Color setting, though.
Confirmed.
klassikmann
klassikmann wroteR101 wroteThe addons update process does lose the Color setting, though.
Confirmed.
klassikmann
This has happened to me twice on an installation which has a local 7" touch screen, but not on an installation with the local screen disabled.
