Thanks for your effort - i use Runeaudio with a Raspberry Pi 2 for 2 years and it's awesome - just works.
As i got a new Raspberry Pi 4 i try out some Distros (Retropie, Lakka, OMV....).
Usually i use Endeavour OS.
Some problems occured:
I installed RuneAudio+R_e2-RPi4.img.xz, got updates, did mirror ranking but i ended up with a confused web-interface.
First autofs/nfs shares got imported but later on they didn't show up on the Library screen any more.
Artists, albums ... all gone - funny though it still showed 2 genres but they were not accessible.
I was able to add 2 radiostations via this screen as well but later on when pushing the "Webradio" button i end up with a blinking rune audio screen.
I decided to do
pacman -Syu
282 pakets got updated and after a reboot i got a pretty emtpy screen,
only the upper bar with the list on the left and search on thr right side without function.
Rebooted again, did
ssh root@192.168.x.xxx
and somehow i was back and things showed up as they should.
Still Webradio got the same behaviour after the pacman update.
Bash shows root@runeaudio+re1:. What happened to re2?
About addons:
TRANSMISSION:
wget -qN --no-check-certificate https://github.com/rern/RuneAudio/raw/master/transmission/install.sh
chmod 755 install.sh
./install.sh ***
./install.sh: line 13: tcolot: command not found
i has no write permission.
Just before i did mkdir -p /usr/share/transmission/web becaue the script first complained about the missing directory.
ARIA:
wget -qN --no-check-certificate https://github.com/rern/RuneAudio/raw/master/aria2/install.sh
./install.sh
. Install Aria2 ...
.i has no write permission.
As i'm logged in as root and folders got same permissions as all the others in /usr/share i don't know how to go on.
RUNEAUDIO+R E1 - IMPORT WEBRADIO:
wget -qN --no-check-certificate https://github.com/rern/RuneAudio-Re1/raw/master/importwebradio.sh
As the adress that is called is not existing i don't wonder this doesn't work.
I added 2 stations manually and they show up as /srv/http/data/webradios/http:||mp3stream3.apasf.apa.at:8000.
But my biggest problem is i still can't import one auto/nfs share.
$ showmount -e 192.168.0.164
Export list for 192.168.0.164:
/home/urschl/Downloads 192.168.0.1/24
$ cat /srv/http/data/system/fstab-zot
192.168.0.164:/home/urschl/Downloads /mnt/MPD/NAS/zot nfs defaults,noauto,bg,soft,timeo=5,rw 0 0
I added the share via GUI/Sources. It's listed tike the others, got green flag but
$ ls -l /mnt/MPD/NAS/zot
show different permissions. I changed that.
Still my files won't get imported.
I connected a second USB DAC (Shanling M0), turned out that wasn't a good idea.
When i go to GUI/MPD i get the buttons but no audio outputs any more.
$ cat /etc/mpd.conf
audio_buffer_size "4096"
auto_update "yes"
bind_to_address "0.0.0.0"
db_file "/srv/http/data/mpd/mpd.db"
log_level "default"
log_file "/var/log/mpd.log"
mixer_type "none"
replaygain "off"
zeroconf_name "RuneAudio"
enabled "no"
resampler {
plugin "soxr"
quality "very high"
name "RaspberryPi Analog Out"
mixer_control "PCM"
mixer_device "hw:0"
name "RaspberryPi HDMI Out"
device "hw:0,1"
mixer_control "PCM"
mixer_device "hw:0"
name "RaspberryPi HDMI Out 2"
device "hw:0,2"
mixer_control "PCM"
mixer_device "hw:0"
name "FiiO USB Audio Class 2.0 DAC"
device "hw:1,0"
So the second DAC wasn't recognized at all.
To get life back to the MPD settings i tried changing settings to auto update and auto play.
Playing audio still works (autoplay as well), only one time i got some high pitched noises, the DAC is used for audio out.
Auto update was a really bad idea, i'm back to: Artists, albums ... all gone - funny though it still showed 2 genres but they were not accessible.
How to get my output back? Any ideas anyone?
