Hi janui:
Thank you very much for your quick answer! Thank you!
I can use
http://runeaudio/dev/gitpull as usual!
In addition: after performing the rune UI gitpull function, do you need to perform the following steps again?
Chown root.root/srv/http/command/lyric.sh
Chown root.root/srv/http/command/artist_info.sh
Chmod 600/srv/http/command/lyric.sh
Chmod 600/srv/http/command/artist_info.sh
Rm-f/var/www/command/mpd-watchdog
Cd/srv/http/
Git config user.email "
any@body.com"
Git config user.name "anybody"
Git stash
Git add.
Git pull
Git stash
CD /home
Several problems remain unresolved after git pull.
Question C: After booting, the browser will always display Please try again later. No matter how the browser refreshes, it will take about 3 minutes to work properly. Is there any way to speed up the boot?
^^^^^ Upgrade is still unresolved! It still takes more than three minutes.
Question D: After the browser shuts down, I find that the HDMI screen is still on display and SSH can continue to log in. It will take three minutes for HDMI to display SHUTDOWN. And the shutdown will be completed soon. Is this BUG? Is there any way to speed up the shutdown?
^^^^ Upgraded, it seems that the browser - turn off - power off & reboot has become completely useless!
Another major problem is that after booting, the browser shows please try again later, which can not be loaded automatically. It must be refreshed manually on the browser until the boot is completed. This process is very annoying. The Bata 0.4 version does not have this problem. This problem seriously affects the use of.... Is there any way to modify it?
Andre
