Been using the 0.5 version for ages and before that 0.4
I've kept to it as the latest version won't play my 352.8 files reliably i.e. after a few minutes they break into static. Stop Runeaudio, start again, all is fine for a few minutes, then static...
Have a problem though with Airplay on the 0.5 version, just doesn't work. Debug is below.
Hope some kind soul can provide a solution!
Linux version 4.14.34-1-ARCH (alarm@alarmpi) (gcc version 7.3.1 20180312 (GCC)) #1 SMP Tue May 15 00:50:02 CDT 2018
System time: Sun May 3 21:58:48 AEST 2020
System load: 1.13 0.27 0.09 2/159 1126
Hardware model: Raspberry Pi 2 Model B Rev 1.1
Linux version: 4.14.34-1-ARCH
RuneOS/UI: 0.5b (gearhead) - Experimental Beta 0.5 20180903
Git Branch: 0.5b
HW platform: RaspberryPi (08)
Build version: janui-20180903-11
PlayerID: 082dc9e97ccf46a931b2e618cd62e4b05a
###### Boot configuration (cat /boot/config.txt) ######
# Uncomment some or all of these to enable the optional hardware interfaces
# Params:
# i2c_arm Set to "on" to enable the ARM's i2c interface
# (default "off")
# i2c_vc Set to "on" to enable the i2c interface
# usually reserved for the VideoCore processor
# (default "off")
# i2c_arm_baudrate Set the baudrate of the ARM's i2c interface
# (default "100000")
# i2c_vc_baudrate Set the baudrate of the VideoCore i2c interface
# i2c_baudrate An alias for i2c_arm_baudrate
# i2s Set to "on" to enable the i2s interface
# (default "off")
# spi Set to "on" to enable the spi interfaces
# (default "off")
# act_led_trigger Choose which activity the LED tracks.
# Use "heartbeat" for a nice load indicator.
# (default "mmc")
# act_led_activelow Set to "on" to invert the sense of the LED
# (default "off")
# act_led_gpio Set which GPIO pin to use for the activity LED
# (in case you want to connect it to an external
# device)
# (default "16" on a non-Plus board, "47" on a
# Plus or Pi 2)
# N.B. It is recommended to only enable those interfaces that are needed.
# Leaving all interfaces enabled can lead to unwanted behaviour (i2c_vc
# interfering with Pi Camera, I2S and SPI hogging GPIO pins, etc.)
# Note also that i2c, i2c_arm and i2c_vc are aliases for the physical
# interfaces i2c0 and i2c1. Use of the numeric variants is still possible
# but deprecated because the ARM/VC assignments differ between board
# revisions. The same board-specific mapping applies to i2c_baudrate,
# and the other i2c baudrate parameters.
## RuneAudio HDMI & 3,5mm jack
dtparam=audio=off
## RuneAudio I2S-Settings
dtoverlay=none
# Uncomment to enable the lirc-rpi module
# Params: gpio_out_pin GPIO pin for output (default "17")
# gpio_in_pin GPIO pin for input (default "18")
# gpio_in_pull Pull up/down/off on the input pin
# (default "down")
# sense Override the IR receive auto-detection logic:
# (default "-1")
# softcarrier Turn the software carrier "on" or "off"
# (default "on")
# (default "off")
# LCD settings
# 180 degrees
# Normal
lcd_rotate=0
## Boot splash
# set to 1 to disable or 0 to enable boot splash
disable_splash=1
# Uncomment if you get no picture on HDMI for a default "safe" mode
# Uncomment this if your display has a black border of unused pixels visible
# and your display can output without overscan
# Uncomment the following to adjust overscan. Use positive numbers if console
# goes off screen, and negative if there is too much border
# Uncomment to force a console size. By default it will be display's size minus
# overscan.
# Uncomment if hdmi display is not detected and composite is being output
# Uncomment to force a specific HDMI mode (this will force VGA)
# Uncomment to force a HDMI mode rather than DVI. This can make audio work in
# DMT (computer monitor) modes
# Uncomment to set monitor mode to DMT
# Uncomment to increase signal to HDMI, if you have interference, blanking, or
# no display
# setting the max usb current to 1200mA
max_usb_current=1
# memory options
gpu_mem=16
## Some overclocking settings, governor is set to on-demand as standard
## The values below are valid for the B+ and Zero models
## Overclocking should not be needed for the 2B, 3B and 3B+ models
## See your documentation for A and B models
## None
## Modest
## Medium
## High
## Turbo
## General CPU settings
force_turbo=1
# Lowering max CPU temperature from 85 (standard) to 70 or 75 degrees gives some protection when (force) turbo is set
# If the max temp is reached the cpu will autmatically be throttled back
# Boot delay sometimes needs to be set to higher values when overclocking is enabled
# Default boot delay is 1 second, 3B+ needs a delay of 2
boot_delay=2
initramfs initramfs-linux.img followkernel
RAM: 973.58MiB 232.79MiB 740.79MiB 20.16MiB
Swap: 0.00B 0.00B 0.00B
Bootup: Sun May 3 21:58:15 2020 Load average: 1.13 0.27 0.09 2/155 1157
user : 00:00:27.55 21.9% page in : 129434
nice : 00:00:03.59 2.9% page out: 19656
system: 00:00:17.05 13.6% page act: 12114
IOwait: 00:00:14.48 11.5% page dea: 0
hw irq: 00:00:00.00 0.0% page flt: 239963
sw irq: 00:00:00.71 0.6% swap in : 0
idle : 00:01:02.32 49.6% swap out: 0
uptime: 00:00:32.52 context : 68465
irq 16: 0 irq 48: 0
irq 17: 12087 irq 50: 3369
irq 21: 0 irq 59: 0
irq 23: 34 irq 62: 32795
irq 24: 2 irq 86: 141
irq 46: 0 irq 87: 30
mmcblk0 3302r 1 mmcblk0p2 3158r
mmcblk0p1 109r sda 120r 0w
eth0 TX 22.57KiB RX 27.93KiB wlan0 TX 6.81KiB RX 36.62KiB
lo TX 325.33KiB RX 325.33KiB
systemd-+-agetty
|-avahi-daemon---avahi-daemon
|-dbus-daemon
|-devmon---devmon---udevil---usbmount---sh---sync
|-2*[dhcpcd]
|-haveged
|-ifplugd
|-mpd---4*[{mpd}]
|-nginx---nginx
|-nmbd
|-php-fpm---3*[php-fpm]
|-python
|-redis-server---3*[{redis-server}]
|-rune_PL_wrk
|-rune_SY_wrk
|-sh---sleep
|-shairport-sync---2*[{shairport-sync}]
|-smbd-+-cleanupd
| `-smbd-notifyd
|-sshd
|-systemd-journal
|-systemd-resolve
|-systemd-timesyn---{systemd-timesyn}
|-systemd-udevd
|-winbindd---2*[winbindd]
|-wpa_actiond
`-wpa_supplicant
Advanced Linux Sound Architecture Driver Version k4.14.34-1-ARCH.
0 [Mojo ]: USB-Audio - Mojo
Chord Electronics Ltd Mojo at usb-3f980000.usb-1.2, high speed
PLAYBACK devices: (aplay -l)
card 0: Mojo [Mojo], device 0: USB Audio [USB Audio]
Subdevices: 1/1
Subdevice #0: subdevice #0
PCM devices: (aplay -L)
null
pulse
PulseAudio Sound Server
default:CARD=Mojo
Mojo, USB Audio
Default Audio Device
sysdefault:CARD=Mojo
Mojo, USB Audio
front:CARD=Mojo,DEV=0
Mojo, USB Audio
Front speakers
surround21:CARD=Mojo,DEV=0
Mojo, USB Audio
2.1 Surround output to Front and Subwoofer speakers
surround40:CARD=Mojo,DEV=0
Mojo, USB Audio
4.0 Surround output to Front and Rear speakers
surround41:CARD=Mojo,DEV=0
Mojo, USB Audio
4.1 Surround output to Front, Rear and Subwoofer speakers
surround50:CARD=Mojo,DEV=0
Mojo, USB Audio
5.0 Surround output to Front, Center and Rear speakers
surround51:CARD=Mojo,DEV=0
Mojo, USB Audio
5.1 Surround output to Front, Center, Rear and Subwoofer speakers
surround71:CARD=Mojo,DEV=0
Mojo, USB Audio
7.1 Surround output to Front, Center, Side, Rear and Woofer speakers
iec958:CARD=Mojo,DEV=0
Mojo, USB Audio
IEC958 (S/PDIF) Digital Audio Output
card 0:
Simple mixer control 'PCM',0
Simple mixer control 'PCM',1
Simple mixer control 'Mojo Validity',0
card 0:
numid=3,iface=MIXER,name='PCM Playback Switch',index=1
numid=4,iface=MIXER,name='PCM Playback Volume'
numid=5,iface=MIXER,name='PCM Playback Volume',index=1
numid=6,iface=MIXER,name='Mojo Validity'
numid=1,iface=PCM,name='Playback Channel Map'
Output 1 (Mojo) is enabled
MPD statistics: (mpc stats)
Artists: 0
Albums: 0
Songs: 0
Play Time: 0 days, 0:00:00
Uptime: 0 days, 0:00:19
DB Updated: Sun May 3 21:57:43 2020
DB Play Time: 0 days, 0:00:00
###### mpd version ######
Music Player Daemon 0.20.20
Copyright (C) 2003-2007 Warren Dukes
Copyright 2008-2017 Max Kellermann
This is free software; see the source for copying conditions. There is NO
warranty; not even MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
Database plugins:
simple proxy upnp
Storage plugins:
local smbclient nfs curl
Neighbor plugins:
smbclient upnp
Decoders plugins:
[mad] mp3 mp2
[vorbis] ogg oga
[oggflac] ogg oga
[flac] flac
[sndfile] wav aiff aif au snd paf iff svx sf voc w64 pvf xi htk caf sd2
[audiofile] wav au aiff aif
[dsdiff] dff
[dsf] dsf
[faad] aac
[mpcdec] mpc
[ffmpeg] 16sv 3g2 3gp 4xm 8svx aa3 aac ac3 adx afc aif aifc aiff al alaw amr anim apc ape asf atrac au aud avi avm2 avs bap bfi c93 cak cin cmv cpk daud dct divx dts dv dvd dxa eac3 film flac flc fli fll flx flv g726 gsm gxf iss m1v m2v m2t m2ts m4a m4b m4v mad mj2 mjpeg mjpg mka mkv mlp mm mmf mov mp+ mp1 mp2 mp3 mp4 mpc mpeg mpg mpga mpp mpu mve mvi mxf nc nsv nut nuv oga ogm ogv ogx oma ogg omg opus psp pva qcp qt r3d ra ram rl2 rm rmvb roq rpl rvc shn smk snd sol son spx str swf tak tgi tgq tgv thp ts tsp tta xa xvid uv uv2 vb vid vob voc vp6 vmd wav webm wma wmv wsaud wsvga wv wve
[pcm]
Filters:
libsamplerate soxr
Tag plugins:
id3tag
Output plugins:
null fifo pipe alsa openal httpd
Encoder plugins:
null vorbis wave flac
Input plugins:
file alsa curl ffmpeg smbclient nfs mms
Playlist plugins:
extm3u m3u pls xspf asx rss soundcloud flac cue embcue
Protocols:
file:// http:// https:// mms:// mmsh:// mmst:// mmsu:// gopher:// rtp:// rtsp:// rtmp:// rtmpt:// rtmps:// smb:// nfs:// alsa://
Other features:
avahi epoll icu inotify systemd tcp un
log_level "default"
zeroconf_name "RuneAudio"
auto_update "no"
audio_buffer_size "4096"
buffer_before_play "10%"
gapless_mp3_playback "no"
mixer_type "disabled"
enabled "no"
# MPD version number: 0.20.20
resampler {
plugin "soxr"
quality "very high"
replaygain "off"
name "Mojo"
dsd_usb "yes"
hardware platform: RaspberryPi
/proc/sys/vm/swappiness: 0
/proc/sys/kernel/sched_latency_ns: 4500000
/proc/sys/kernel/sched_rr_timeslice_ms: 100
Module = "snd_usb_audio"
Attributes:
coresize = "159744"
initsize = "0"
initstate = "live"
refcnt = "0"
taint = ""
uevent =
Parameters:
autoclock = "Y"
device_setup = "0,0,0,0,0,0,0,0"
enable = "Y,Y,Y,Y,Y,Y,Y,Y"
id = "(null),(null),(null),(null),(null),(null),(null),(null)"
ignore_ctl_error = "N"
index = "-1,-1,-1,-1,-1,-1,-1,-1"
pid = "-1,-1,-1,-1,-1,-1,-1,-1"
quirk_alias = "(null),(null),(null),(null),(null),(null),(null),(null)"
vid = "-1,-1,-1,-1,-1,-1,-1,-1"
Sections:
.ARM.exidx = "0x7f2669c4"
.ARM.exidx.exit.text= "0x7f263cd0"
.ARM.exidx.init.text= "0x7f263cc8"
.alt.smp.init = "0x7f2669bc"
.bss = "0x7f269d80"
.data = "0x7f268000"
.exit.text = "0x7f25e424"
.gnu.linkonce.this_module= "0x7f269b80"
.init.text = "0x7f275000"
.note.gnu.build-id = "0x7f25f000"
.rodata = "0x7f25f028"
.rodata.str1.4 = "0x7f263cd8"
.strtab = "0x7f27c4a0"
.symtab = "0x7f276000"
.text = "0x7f24d000"
__param = "0x7f266908"
total 8.0K
drwxr-xr-x 2 root root 4.0K May 3 21:49 .
drwxr-xr-x 6 root root 4.0K May 3 21:44 ..
lrwxrwxrwx 1 root root 44 Jan 29 2017 amixer-webui.service -> /usr/lib/systemd/system/amixer-webui.service
lrwxrwxrwx 1 root root 41 Mar 13 2018 brcm43438.service -> /usr/lib/systemd/system/brcm43438.service
lrwxrwxrwx 1 root root 39 Feb 9 2015 haveged.service -> /usr/lib/systemd/system/haveged.service
lrwxrwxrwx 1 root root 44 May 3 21:49 netctl-auto@wlan0.service -> /usr/lib/systemd/system/netctl-auto@.service
lrwxrwxrwx 1 root root 47 May 3 21:43 netctl-ifplugd@eth0.service -> /usr/lib/systemd/system/netctl-ifplugd@.service
lrwxrwxrwx 1 root root 37 Feb 15 2015 nginx.service -> /usr/lib/systemd/system/nginx.service
lrwxrwxrwx 1 root root 37 Feb 15 2015 redis.service -> /usr/lib/systemd/system/redis.service
lrwxrwxrwx 1 root root 45 Feb 15 2015 rune_shutdown.service -> /usr/lib/systemd/system/rune_shutdown.service
lrwxrwxrwx 1 root root 43 Feb 15 2015 rune_SY_wrk.service -> /usr/lib/systemd/system/rune_SY_wrk.service
lrwxrwxrwx 1 root root 36 Feb 9 2015 sshd.service -> /usr/lib/systemd/system/sshd.service
lrwxrwxrwx 1 root root 48 Mar 13 2018 systemd-resolved.service -> /usr/lib/systemd/system/systemd-resolved.service
sys /sys sysfs rw,nosuid,nodev,noexec,relatime 0 0
dev /dev devtmpfs rw,nosuid,relatime,size=491284k,nr_inodes=122821,mode=755 0 0
run /run tmpfs rw,nosuid,nodev,relatime,mode=755 0 0
/dev/mmcblk0p2 / ext4 rw,relatime,stripe=32679,data=ordered 0 0
cgroup2 /sys/fs/cgroup/unified cgroup2 rw,nosuid,nodev,noexec,relatime,nsdelegate 0 0
cgroup /sys/fs/cgroup/systemd cgroup rw,nosuid,nodev,noexec,relatime,xattr,name=systemd 0 0
bpf /sys/fs/bpf bpf rw,nosuid,nodev,noexec,relatime,mode=700 0 0
cgroup /sys/fs/cgroup/pids cgroup rw,nosuid,nodev,noexec,relatime,pids 0 0
systemd-1 /proc/sys/fs/binfmt_misc autofs rw,relatime,fd=35,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=11381 0 0
tmpfs /tmp tmpfs rw,nosuid,nodev 0 0
http-tmp /srv/http/tmp tmpfs rw,nosuid,nodev,noatime,size=5120k,uid=33,gid=33 0 0
var-tmp /var/tmp tmpfs rw,nosuid,nodev,noatime,size=5120k 0 0
dev 480M 0 480M 0% /dev
run 487M 13M 475M 3% /run
/dev/mmcblk0p2 7.1G 2.4G 4.6G 35% /
tmpfs 487M 0 487M 0% /dev/shm
tmpfs 487M 0 487M 0% /sys/fs/cgroup
tmpfs 487M 0 487M 0% /tmp
logs 5.0M 20K 5.0M 1% /var/log
http-tmp 5.0M 4.0K 5.0M 1% /srv/http/tmp
var-tmp 5.0M 0 5.0M 0% /var/tmp
rune-logs 5.0M 24K 5.0M 1% /var/log/runeaudio
/dev/mmcblk0p1 100M 22M 79M 22% /boot
###### Filesystem mounts - partitions (parted -ls) ######
Model: WD Elements 25A2 (scsi)
Disk /dev/sda: 3001GB
Sector size (logical/physical): 512B/4096B
Partition Table: gpt
Disk Flags:
Number Start End Size File system Name Flags
1 20.5kB 210MB 210MB fat32 EFI System Partition boot, esp
2 210MB 3000GB 3000GB hfs+
Model: SD SL08G (sd/mmc)
Disk /dev/mmcblk0: 7948MB
Sector size (logical/physical): 512B/512B
Partition Table: msdos
Disk Flags:
Number Start End Size Type File system Flags
1 1049kB 106MB 105MB primary fat16 lba
2 106MB 7948MB 7842MB primary ext4
###### Hard Disk Drive - SMART Health Check (smartctl /dev/sda -d sat -H -i | grep -E 'Model:|Capacity:|-health self-|SMART support is') ######
Device Model: WDC WD30NMZW-11LG6S0
User Capacity: 3,000,559,427,584 bytes [3.00 TB]
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
SMART overall-health self-assessment test result: PASSED
###### Loaded kernel modules (lsmod) ######
Module Size Used by
nls_utf8 16384 0
8021q 28672 0
garp 16384 1 8021q
mrp 20480 1 8021q
stp 16384 1 garp
llc 16384 2 garp,stp
ccm 20480 6
arc4 16384 2
rt2800usb 28672 0
rt2800lib 110592 1 rt2800usb
rt2x00usb 20480 1 rt2800usb
rt2x00lib 53248 3 rt2800lib,rt2800usb,rt2x00usb
mac80211 647168 3 rt2800lib,rt2x00lib,rt2x00usb
snd_usb_audio 159744 0
cfg80211 577536 2 rt2x00lib,mac80211
snd_hwdep 16384 1 snd_usb_audio
snd_usbmidi_lib 28672 1 snd_usb_audio
snd_rawmidi 32768 1 snd_usbmidi_lib
snd_seq_device 16384 1 snd_rawmidi
snd_pcm 94208 1 snd_usb_audio
crc_ccitt 16384 1 rt2800lib
snd_timer 32768 1 snd_pcm
snd 65536 7 snd_hwdep,snd_usb_audio,snd_timer,snd_rawmidi,snd_usbmidi_lib,snd_seq_device,snd_pcm
bcm2835_rng 16384 0
rng_core 16384 1 bcm2835_rng
fixed 16384 0
uio_pdrv_genirq 16384 0
uio 16384 1 uio_pdrv_genirq
sch_fq_codel 20480 6
crypto_user 16384 0
ip_tables 24576 0
x_tables 24576 1 ip_tables
ipv6 438272 48
tcp 0 0 0.0.0.0:5000 0.0.0.0:* LISTEN 590/shairport-sync
tcp 0 0 0.0.0.0:6600 0.0.0.0:* LISTEN 409/mpd
tcp 0 0 0.0.0.0:139 0.0.0.0:* LISTEN 1102/smbd
tcp 0 0 127.0.0.1:6379 0.0.0.0:* LISTEN 286/redis-server 12
tcp 0 0 0.0.0.0:5355 0.0.0.0:* LISTEN 235/systemd-resolve
tcp 0 0 0.0.0.0:111 0.0.0.0:* LISTEN 1/init
tcp 0 0 0.0.0.0:8080 0.0.0.0:* LISTEN 253/python
tcp 0 0 0.0.0.0:80 0.0.0.0:* LISTEN 292/nginx: master p
tcp 0 0 0.0.0.0:81 0.0.0.0:* LISTEN 292/nginx: master p
tcp 0 0 0.0.0.0:82 0.0.0.0:* LISTEN 292/nginx: master p
tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 285/sshd
tcp 0 0 0.0.0.0:445 0.0.0.0:* LISTEN 1102/smbd
tcp6 0 0 :::5000 :::* LISTEN 590/shairport-sync
tcp6 0 0 :::5355 :::* LISTEN 235/systemd-resolve
tcp6 0 0 :::139 :::* LISTEN 1102/smbd
tcp6 0 0 :::111 :::* LISTEN 1/init
tcp6 0 0 :::22 :::* LISTEN 285/sshd
tcp6 0 0 :::445 :::* LISTEN 1102/smbd
udp 0 0 0.0.0.0:57383 0.0.0.0:* 252/avahi-daemon: r
udp 0 0 127.0.0.53:53 0.0.0.0:* 235/systemd-resolve
udp 0 0 0.0.0.0:68 0.0.0.0:* 641/dhcpcd
udp 0 0 0.0.0.0:68 0.0.0.0:* 916/dhcpcd
udp 0 0 0.0.0.0:111 0.0.0.0:* 1/init
udp 0 0 192.168.0.255:137 0.0.0.0:* 1080/nmbd
udp 0 0 192.168.0.29:137 0.0.0.0:* 1080/nmbd
udp 0 0 192.168.0.30:137 0.0.0.0:* 1080/nmbd
udp 0 0 0.0.0.0:137 0.0.0.0:* 1080/nmbd
udp 0 0 192.168.0.255:138 0.0.0.0:* 1080/nmbd
udp 0 0 192.168.0.29:138 0.0.0.0:* 1080/nmbd
udp 0 0 192.168.0.30:138 0.0.0.0:* 1080/nmbd
udp 0 0 0.0.0.0:138 0.0.0.0:* 1080/nmbd
udp 0 0 0.0.0.0:5353 0.0.0.0:* 252/avahi-daemon: r
udp 0 0 0.0.0.0:5355 0.0.0.0:* 235/systemd-resolve
udp6 0 0 :::111 :::* 1/init
udp6 0 0 :::5355 :::* 235/systemd-resolve
unix 2 [ ACC ] STREAM LISTENING 18949 409/mpd /run/mpd.sock
unix 2 [ ACC ] STREAM LISTENING 15372 286/redis-server 12 /run/redis.sock
unix 2 [ ACC ] STREAM LISTENING 19769 733/php-fpm: master /var/run/php-command.sock
unix 2 [ ACC ] STREAM LISTENING 19772 733/php-fpm: master /var/run/php-db.sock
unix 2 [ ACC ] STREAM LISTENING 19775 733/php-fpm: master /var/run/php-display.sock
unix 2 [ ACC ] STREAM LISTENING 21833 1067/winbindd /var/run/samba/winbindd/pipe
unix 2 [ ACC ] STREAM LISTENING 11350 1/init /run/systemd/private
unix 2 [ ACC ] STREAM LISTENING 15195 1/init /run/dbus/system_bus_socket
unix 2 [ ACC ] STREAM LISTENING 15199 1/init /run/avahi-daemon/socket
unix 2 [ ACC ] STREAM LISTENING 11364 1/init /run/rpcbind.sock
unix 2 [ ACC ] STREAM LISTENING 21864 1080/nmbd /var/run/samba/nmbd/unexpected
unix 2 [ ACC ] SEQPACKET LISTENING 11375 1/init /run/systemd/coredump
unix 2 [ ACC ] SEQPACKET LISTENING 11390 1/init /run/udev/control
unix 2 [ ACC ] STREAM LISTENING 11393 1/init /run/systemd/journal/stdout
unix 2 [ ACC ] STREAM LISTENING 21835 1067/winbindd /var/lib/samba/winbindd_privileged/pipe
