janui wroteHi nic,
nic wroteI've been a happy user of 0.5b for the past few weeks and really appreciate janui's help getting my DAC working with the new image . I've run into a slight issue when casting , I get 'twittering noises' type static . I have rebooted the PC used for casting , rebooted the PI and also done a gitpull . This issue happens with MP3 cast from my PC , WAVs now seen fine. Any ideas?
I have searched on the net for this problem, unfortunately found nothing similar with a recent date. So it will be a bit of an experimental approach.
Could you first try a few simple things first. In the /dev UI try setting SoXr for MPD ON or OFF (I don’t know what your normal setting is), then reboot & test. Then try selecting the Allo Piano 2.1 DAC Plus (without Kali) in the Settings UI, reboot, check that the correct output is selected in the MPD UI and retest.
If there is no improvement in sound quality then revert to your normal settings. Upgrading the upmpdcli package could fix it, so let’s try it. Log in with SSH and run the following commands:
cd /home
wget https://github.com/gearhead/RuneOS/raw/master/packages/upmpdcli-rune/upmpdcli-rune-1.3.0-1-armv7h.pkg.tar.xz
pacman -U upmpdcli-rune-1.3.0-1-armv7h.pkg.tar.xz --force
Then:
rm upmpdcli-rune-1.3.0-1-armv7h.pkg.tar.xz
cp /var/www/app/config/defaults/upmpdcli.conf /etc/upmpdcli.conf
cp /var/www/app/config/defaults/upmpdcli.service /usr/lib/systemd/system/upmpdcli.service
find /usr/lib/systemd/system -name *.service -exec chmod 644 {} \;
find /etc -name *.conf -exec chmod 644 {} \;
redis-cli hset dlna enable 0
redis-cli hset dlna queueowner 0
redis-cli hset dlna name RuneAudio
Then via the Settings UI switch ‘UPnP / DLNA’ ON, configure it, reboot and retest.
If this changes nothing then it is probably better to revert back to the original version of upmpdcli package, but this is optional and up to you. To revert back, run the following commands:
cd /home
wget https://github.com/gearhead/RuneOS/raw/master/packages/upmpdcli-rune/upmpdcli-rune-1.2.15-3-armv7h.pkg.tar.xz
pacman -R upmpdcli-rune
Then:
pacman -U upmpdcli-rune-1.2.15-3-armv7h.pkg.tar.xz
Then:
Then via the Settings UI switch ‘UPnP / DLNA’ ON, configure it, reboot and retest to check that it still works.
