Hi janui,
janui wroteIf you select the I2S kernel module for the ES90x8 (Sabre) in the Settings UI you will get better performance.
Agree. Although the ES90x8 (Sabre) I2S kernel module is limited to 192kHz, it sounds a lot better than the hifiberry module.
janui wroteYou can also disable the on board WiFi with by adding this line to config.txt:
dtoverlay=pi3-disable-wifi
I disable wifi by using hondagx35's suggestion for 0.4b, it works for me.
1. modify the file "/etc/modprobe.d/disable_rpi3_wifi_bt.conf" by uncomment the following lines
blacklist brcmfmac
blacklist brcmutil
2. disable the wifi service:
systemctl disable netctl-auto@wlan0
Regarding the "Disk Errors, Action Required" message on RuneUI, I think I find the cause. My Pi B+ connects to Suptronics X4000K Kit which has a harddisk expansion board. However, the board does not have a harddisk attached to. RuneOS sees /dev/sda but finds no physical blocks. The warning message maybe triggered by the SMART Health Check service (copied from debug).
smartctl /dev/sda -d sat -H -i | grep -E 'Model:|Capacity:|-health self-|SMART support is'
This command line would not appear if the harddisk expansion board is disconnected from Pi B+.
The warning message comes out only when MPD is playing. I believe this warning won't harm anyway.
The "
CIFS VFS: ioctl error in smb2_get_dfs_refer rc=-2" message from dmesg is another issue. Having search around the Internet, it seems to be related to kernel/smb settings. Here is my NAS network mount settings (copied from debug):
//192.168.0.11/SSOTS/HiRes_Music /mnt/MPD/NAS/HiRes_Music cifs ro,relatime,vers=2.1,sec=ntlmssp,cache=none,username=cubox,domain=,uid=1000,forceuid,gid=92,forcegid,addr=192.168.0.11,file_mode=0755,dir_mode=0755,soft,nounix,mapposix,rsize=8192,wsize=16384,echo_interval=60,actimeo=1 0 0
My NAS supports up to smb/cifs version 2.1.
Any idea?
MidnightExpress
