tml3nr wrotefox.peko wroteHello,
I am write in case of freeze playback window . I have connected usb external 500GB disk 2.5'
with 19 000+ songs around.Everything is slow or freeze when I load fully playlist. Is some possible fix for it . It is little bit wierd. Pc, phone work with this quantity without any problems.
Thank you for any answear.
Check your power supply. I have used rpi 2 with USB WD 1TB contains more than 42,000 songs. It works perfectly.
I am using standard power supply, 5V 2,5A. I will receive sata extension Suptronics 820x with 5V 4A power supply. Maybe that will by ok, what do you think?
Thank you[/quote]
I have not used the sata extension so I do not know how.
Did you try changing to another usb hdd?[/quote]
sata extension with new hdd and power supply. Freeze again, from playback screen to playlist with all of my music.
I do not know where is the problem.
