So I can't attach the file, it's says the extension is not allowed...
rootfs / rootfs rw 0 0
/dev/root / ext4 rw,noatime,nodiratime,nouser_xattr,errors=remount-ro,data=ordered 0 0
devtmpfs /dev devtmpfs rw,relatime,size=242780k,nr_inodes=60695,mode=755 0 0
cgroup /sys/fs/cgroup/cpu,cpuacct cgroup rw,nosuid,nodev,noexec,relatime,cpuacct,cpu 0 0
cgroup /sys/fs/cgroup/net_prio cgroup rw,nosuid,nodev,noexec,relatime,net_prio 0 0
systemd-1 /proc/sys/fs/binfmt_misc autofs rw,relatime,fd=22,pgrp=1,timeout=300,minproto=5,maxproto=5,direct 0 0
tmpfs /tmp tmpfs rw 0 0
logs /var/log ramfs rw,nosuid,nodev,noatime,mode=1777,size=1M 0 0
rune-logs /var/log/runeaudio ramfs rw,nosuid,nodev,noatime,mode=1777,size=10M 0 0
//192.168.1.1/thakmusic/ /mnt/MPD/NAS/ThakMusic cifs ro,relatime,vers=1.0,sec=ntlm,cache=none,uid=45,forceuid,gid=45,forcegid,addr=192.168.1.1,file_mode=0755,dir_mode=0755,nounix,rsize=16384,wsize=17408,actimeo=1 0 0
/dev/root 1.7G 699M 842M 46% /
devtmpfs 238M 0 238M 0% /dev
tmpfs 242M 0 242M 0% /dev/shm
tmpfs 242M 292K 241M 1% /run
tmpfs 242M 0 242M 0% /sys/fs/cgroup
tmpfs 242M 20K 242M 1% /tmp
/dev/mmcblk0p1 90M 43M 48M 47% /boot
//192.168.1.1/thakmusic/ 150G 121G 29G 82% /mnt/MPD/NAS/ThakMusic
###### Kernel status (dmesg) ######
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 3.12.26-1-ARCH (nobody@root-armv6-copy) (gcc version 4.8.2 20131219 (prerelease) (GCC) ) #1 PREEMPT Fri Aug 8 17:40:14 MDT 2014
[ 0.000000] CPU: ARMv6-compatible processor [410fb767] revision 7 (ARMv7), cr=00c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
[ 0.000000] Machine: BCM2708
[ 0.000000] cma: CMA: reserved 8 MiB at 1e800000
[ 0.000000] Memory policy: ECC disabled, Data cache writeback
[ 0.000000] On node 0 totalpages: 126976
[ 0.000000] free_area_init_node: node 0, pgdat c089bdf4, node_mem_map c097b000
[ 0.000000] Normal zone: 992 pages used for memmap
[ 0.000000] Normal zone: 126976 pages, LIFO batch:31
[ 0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
[ 0.000000] pcpu-alloc: [0] 0
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 125984
[ 0.000000] Kernel command line: dma.dmachans=0x7f35 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2708.boardrev=0xe bcm2708.serial=0xf0fcb8af smsc95xx.macaddr=B8:27:EB:FC:B8:AF sdhci-bcm2708.emmc_clock_freq=250000000 vc_mem.mem_base=0x1fa00000 vc_mem.mem_size=0x20000000 ipv6.disable=1 avoid_safe_mode=1 selinux=0 plymouth.enable=0 smsc95xx.turbo_mode=N dwc_otg.lpm_enable=0 dwc_otg.fiq_enable=1 dwc_otg.fiq_fsm_enable=1 dwc_otg.fiq_fsm_mask=0x3 console=tty1 root=/dev/mmcblk0p5 rootfstype=ext4 elevator=noop apparmor=0 security="" rootwait
[ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Memory: 485564K/507904K available (6133K kernel code, 334K rwdata, 2096K rodata, 245K init, 858K bss, 22340K reserved)
fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
vmalloc : 0xdf800000 - 0xff000000 ( 504 MB)
lowmem : 0xc0000000 - 0xdf000000 ( 496 MB)
modules : 0xbf000000 - 0xc0000000 ( 16 MB)
.text : 0xc0008000 - 0xc0811598 (8230 kB)
.init : 0xc0812000 - 0xc084f59c ( 246 kB)
.data : 0xc0850000 - 0xc08a39ac ( 335 kB)
.bss : 0xc08a39ac - 0xc097a2f0 ( 859 kB)
[ 0.000000] SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] NR_IRQS:394
[ 0.000000] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 4294967ms
[ 0.000000] Switching to timer-based delay loop
[ 0.000000] Console: colour dummy device 80x30
[ 0.000000] console [tty1] enabled
[ 0.000634] Calibrating delay loop (skipped), value calculated using timer frequency.. 2.00 BogoMIPS (lpj=10000)
[ 0.000660] pid_max: default: 32768 minimum: 301
[ 0.001157] Mount-cache hash table entries: 512
[ 0.002010] Initializing cgroup subsys memory
[ 0.002092] Initializing cgroup subsys devices
[ 0.002114] Initializing cgroup subsys freezer
[ 0.002132] Initializing cgroup subsys blkio
[ 0.002146] Initializing cgroup subsys perf_event
[ 0.002182] Initializing cgroup subsys net_prio
[ 0.002317] CPU: Testing write buffer coherency: ok
[ 0.002781] Setting up static identity map for 0xc05d7458 - 0xc05d74b4
[ 0.005043] devtmpfs: initialized
[ 0.022550] VFP support v0.3: implementor 41 architecture 1 part 20 variant b rev 5
[ 0.023888] xor: measuring software checksum speed
[ 0.120351] arm4regs : 974.000 MB/sec
[ 0.220401] 8regs : 470.800 MB/sec
[ 0.320510] 32regs : 470.800 MB/sec
[ 0.320530] xor: using function: arm4regs (974.000 MB/sec)
[ 0.321778] NET: Registered protocol family 16
[ 0.327520] DMA: preallocated 4096 KiB pool for atomic coherent allocations
[ 0.328179] cpuidle: using governor ladder
[ 0.328202] cpuidle: using governor menu
[ 0.329012] bcm2708.uart_clock = 0
[ 0.331135] hw-breakpoint: found 6 breakpoint and 1 watchpoint registers.
[ 0.331156] hw-breakpoint: maximum watchpoint size is 4 bytes.
[ 0.331173] mailbox: Broadcom VideoCore Mailbox driver
[ 0.331256] bcm2708_vcio: mailbox at f200b880
[ 0.331352] bcm_power: Broadcom power driver
[ 0.331372] bcm_power_open() -> 0
[ 0.331384] bcm_power_request(0, 8)
[ 0.832097] bcm_mailbox_read -> 00000080, 0
[ 0.832117] bcm_power_request -> 0
[ 0.832365] Serial: AMBA PL011 UART driver
[ 0.832502] dev:f1: ttyAMA0 at MMIO 0x20201000 (irq = 83, base_baud = 0) is a PL011 rev3
[ 0.858873] bio: create slab at 0
[ 1.022375] raid6: int32x1 46 MB/s
[ 1.192434] raid6: int32x2 71 MB/s
[ 1.362546] raid6: int32x4 91 MB/s
[ 1.532708] raid6: int32x8 99 MB/s
[ 1.532728] raid6: using algorithm int32x8 (99 MB/s)
[ 1.532742] raid6: using intx1 recovery algorithm
[ 1.533368] SCSI subsystem initialized
[ 1.533717] usbcore: registered new interface driver usbfs
[ 1.533832] usbcore: registered new interface driver hub
[ 1.534130] usbcore: registered new device driver usb
[ 1.536923] Switched to clocksource stc
[ 1.561805] FS-Cache: Loaded
[ 1.562116] CacheFiles: Loaded
[ 1.576358] NET: Registered protocol family 2
[ 1.577612] TCP established hash table entries: 4096 (order: 3, 32768 bytes)
[ 1.577754] TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
[ 1.577857] TCP: Hash tables configured (established 4096 bind 4096)
[ 1.577941] TCP: reno registered
[ 1.577969] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 1.578004] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 1.578473] NET: Registered protocol family 1
[ 1.579129] RPC: Registered named UNIX socket transport module.
[ 1.579154] RPC: Registered udp transport module.
[ 1.579167] RPC: Registered tcp transport module.
[ 1.579179] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.581113] bcm2708_dma: DMA manager at f2007000
[ 1.581249] bcm2708_gpio: bcm2708_gpio_probe c085e470
[ 1.581734] vc-mem: phys_addr:0x00000000 mem_base=0x1fa00000 mem_size:0x20000000(512 MiB)
[ 1.792235] VFS: Disk quotas dquot_6.5.2
[ 1.792570] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 1.794742] FS-Cache: Netfs 'nfs' registered for caching
[ 1.795808] NFS: Registering the id_resolver key type
[ 1.795908] Key type id_resolver registered
[ 1.795927] Key type id_legacy registered
[ 1.797612] bio: create slab at 1
[ 1.799154] Btrfs loaded
[ 1.800277] aufs 3.12.x-20140804
[ 1.800332] msgmni has been set to 964
[ 1.802684] async_tx: api initialized (async)
[ 1.803055] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[ 1.803399] io scheduler noop registered (default)
[ 1.803423] io scheduler deadline registered
[ 1.803725] io scheduler cfq registered
[ 1.805086] BCM2708FB: allocated DMA memory 5ec00000
[ 1.805156] BCM2708FB: allocated DMA channel 0 @ f2007000
[ 1.809297] Console: switching to colour frame buffer device 82x26
[ 1.811798] uart-pl011 dev:f1: no DMA platform data
[ 1.812455] vc-cma: Videocore CMA driver
[ 1.812477] vc-cma: vc_cma_base = 0x00000000
[ 1.812491] vc-cma: vc_cma_size = 0x00000000 (0 MiB)
[ 1.812502] vc-cma: vc_cma_initial = 0x00000000 (0 MiB)
[ 1.822697] brd: module loaded
[ 1.828433] loop: module loaded
[ 1.828731] vchiq: vchiq_init_state: slot_zero = 0xde800000, is_master = 0
[ 1.829660] Loading iSCSI transport class v2.0-870.
[ 1.832455] usbcore: registered new interface driver ax88179_178a
[ 1.832606] usbcore: registered new interface driver smsc95xx
[ 1.832808] usbcore: registered new interface driver cdc_ncm
[ 1.832834] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 2.033249] Core Release: 2.80a
[ 2.033281] Setting default values for core params
[ 2.033327] Finished setting default values for core params
[ 2.233381] Using Buffer DMA mode
[ 2.233407] Periodic Transfer Interrupt Enhancement - disabled
[ 2.233420] Multiprocessor Interrupt Enhancement - disabled
[ 2.233434] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 2.233453] Dedicated Tx FIFOs mode
[ 2.233841] WARN::dwc_otg_hcd_init:1042: FIQ DMA bounce buffers: virt = 0xdec14000 dma = 0x5ec14000 len=9024
[ 2.233878] FIQ FSM acceleration enabled for :
Periodic Split Transactions
[ 2.233905] dwc_otg: Microframe scheduler enabled
[ 2.233967] WARN::hcd_init:473: FIQ at 0xc04590d8
[ 2.233987] WARN::hcd_init:474: FIQ ASM at 0xc045938c length 36
[ 2.234019] WARN::hcd_init:500: MPHI regs_base at 0xdf806000
[ 2.234051] dwc_otg bcm2708_usb: DWC OTG Controller
[ 2.234105] dwc_otg bcm2708_usb: new USB bus registered, assigned bus number 1
[ 2.234202] dwc_otg bcm2708_usb: irq 32, io mem 0x00000000
[ 2.234245] Init: Port Power? op_state=1
[ 2.234257] Init: Power Port (0)
[ 2.234596] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.234623] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.234642] usb usb1: Product: DWC OTG Controller
[ 2.234661] usb usb1: Manufacturer: Linux 3.12.26-1-ARCH dwc_otg_hcd
[ 2.234678] usb usb1: SerialNumber: bcm2708_usb
[ 2.235534] hub 1-0:1.0: USB hub found
[ 2.235629] hub 1-0:1.0: 1 port detected
[ 2.236117] dwc_otg: FIQ enabled
[ 2.236135] dwc_otg: NAK holdoff enabled
[ 2.236148] dwc_otg: FIQ split-transaction FSM enabled
[ 2.236169] Module dwc_common_port init
[ 2.236640] usbcore: registered new interface driver usb-storage
[ 2.237072] mousedev: PS/2 mouse device common for all mice
[ 2.237555] md: linear personality registered for level -1
[ 2.237579] md: raid0 personality registered for level 0
[ 2.237593] md: raid1 personality registered for level 1
[ 2.237607] md: raid10 personality registered for level 10
[ 2.237974] md: raid6 personality registered for level 6
[ 2.237994] md: raid5 personality registered for level 5
[ 2.238007] md: raid4 personality registered for level 4
[ 2.238022] md: multipath personality registered for level -4
[ 2.238034] md: faulty personality registered for level -5
[ 2.238501] device-mapper: uevent: version 1.0.3
[ 2.239034] device-mapper: ioctl: 4.26.0-ioctl (2013-08-15) initialised: dm-devel@redhat.com
[ 2.239912] device-mapper: multipath: version 1.6.0 loaded
[ 2.239942] device-mapper: multipath round-robin: version 1.0.0 loaded
[ 2.239958] device-mapper: multipath queue-length: version 0.1.0 loaded
[ 2.239973] device-mapper: multipath service-time: version 0.2.0 loaded
[ 2.239993] device-mapper: raid: Loading target version 1.5.2
[ 2.240247] bcm2835-cpufreq: min=700000 max=700000 cur=700000
[ 2.240355] bcm2835-cpufreq: switching to governor ondemand
[ 2.240373] bcm2835-cpufreq: switching to governor ondemand
[ 2.240556] sdhci: Secure Digital Host Controller Interface driver
[ 2.240573] sdhci: Copyright(c) Pierre Ossman
[ 2.240667] sdhci: Enable low-latency mode
[ 2.276981] mmc0: SDHCI controller on BCM2708_Arasan [platform] using platform's DMA
[ 2.277247] mmc0: BCM2708 SDHC host at 0x20300000 DMA 2 IRQ 77
[ 2.277350] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.277375] ledtrig-cpu: registered to indicate activity on CPUs
[ 2.277540] hidraw: raw HID events driver (C) Jiri Kosina
[ 2.278065] usbcore: registered new interface driver usbhid
[ 2.278085] usbhid: USB HID core driver
[ 2.278876] zram: Created 1 device(s) ...
[ 2.279449] TCP: cubic registered
[ 2.279476] Initializing XFRM netlink socket
[ 2.279519] NET: Registered protocol family 17
[ 2.279708] Key type dns_resolver registered
[ 2.287796] registered taskstats version 1
[ 2.294171] md: Waiting for all devices to be available before autodetect
[ 2.294197] md: If you don't use raid, use raid=noautodetect
[ 2.299553] md: Autodetecting RAID arrays.
[ 2.301697] md: Scanned 0 and added 0 devices.
[ 2.301714] md: autorun ...
[ 2.301725] md: ... autorun DONE.
[ 2.302129] Waiting for root device /dev/mmcblk0p5...
[ 2.340176] mmc0: read SD Status register (SSR) after 2 attempts
[ 2.345348] mmc0: new high speed SDHC card at address 1234
[ 2.346022] mmcblk0: mmc0:1234 SA08G 7.28 GiB
[ 2.349229] mmcblk0: p1 p2 < p5 >
[ 2.426335] EXT4-fs (mmcblk0p5): mounted filesystem with ordered data mode. Opts: (null)
[ 2.426436] VFS: Mounted root (ext4 filesystem) on device 179:5.
[ 2.427213] Indeed it is in host mode hprt0 = 00021501
[ 2.446021] devtmpfs: mounted
[ 2.446809] Freeing unused kernel memory: 244K (c0812000 - c084f000)
[ 2.607127] usb 1-1: new high-speed USB device number 2 using dwc_otg
[ 2.607333] Indeed it is in host mode hprt0 = 00001101
[ 2.807426] usb 1-1: New USB device found, idVendor=0424, idProduct=9512
[ 2.807461] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2.808443] hub 1-1:1.0: USB hub found
[ 2.808632] hub 1-1:1.0: 3 ports detected
[ 2.932162] systemd[1]: systemd 216 running in system mode. (+PAM -AUDIT -SELINUX -IMA -APPARMOR +SMACK -SYSVINIT +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ -LZ4 +SECCOMP +BLKID -ELFUTILS +KMOD -IDN )
[ 2.933073] systemd[1]: Detected architecture 'arm'.
[ 3.087222] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[ 3.119531] IPv6: Loaded, but administratively disabled, reboot required to enable
[ 3.119726] systemd[1]: Inserted module 'ipv6'
[ 3.131732] systemd[1]: Set hostname to .
[ 3.187612] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[ 3.187649] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 3.190655] smsc95xx v1.0.4
[ 3.253509] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-bcm2708_usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:fc:b8:af
[ 3.337240] usb 1-1.2: new high-speed USB device number 4 using dwc_otg
[ 3.438924] usb 1-1.2: New USB device found, idVendor=7392, idProduct=7811
[ 3.438960] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 3.438985] usb 1-1.2: Product: 802.11n WLAN Adapter
[ 3.439002] usb 1-1.2: Manufacturer: Realtek
[ 3.439020] usb 1-1.2: SerialNumber: 00e04c000001
[ 3.978818] systemd[1]: Cannot add dependency job for unit display-manager.service, ignoring: Unit display-manager.service failed to load: No such file or directory.
[ 3.989864] systemd[1]: Starting Forward Password Requests to Wall Directory Watch.
[ 3.990808] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 3.991148] systemd[1]: Expecting device sys-subsystem-net-devices-eth0.device...
[ 3.992041] systemd[1]: Starting Remote File Systems.
[ 3.992863] systemd[1]: Reached target Remote File Systems.
[ 3.993315] systemd[1]: Starting Dispatch Password Requests to Console Directory Watch.
[ 3.993951] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ 3.994235] systemd[1]: Starting Paths.
[ 3.995050] systemd[1]: Reached target Paths.
[ 3.995362] systemd[1]: Starting Encrypted Volumes.
[ 3.996178] systemd[1]: Reached target Encrypted Volumes.
[ 3.996688] systemd[1]: Starting Arbitrary Executable File Formats File System Automount Point.
[ 3.998760] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 3.999153] systemd[1]: Starting Swap.
[ 3.999964] systemd[1]: Reached target Swap.
[ 4.000283] systemd[1]: Expecting device dev-mmcblk0p1.device...
[ 4.001086] systemd[1]: Starting Root Slice.
[ 4.070116] systemd[1]: Created slice Root Slice.
[ 4.070467] systemd[1]: Starting Device-mapper event daemon FIFOs.
[ 4.071757] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[ 4.072179] systemd[1]: Starting udev Control Socket.
[ 4.073445] systemd[1]: Listening on udev Control Socket.
[ 4.073783] systemd[1]: Starting Journal Socket (/dev/log).
[ 4.073868] systemd[1]: Socket service systemd-journald.service not loaded, refusing.
[ 4.075370] systemd[1]: Failed to listen on Journal Socket (/dev/log).
[ 4.075766] systemd[1]: Starting Delayed Shutdown Socket.
[ 4.076907] systemd[1]: Listening on Delayed Shutdown Socket.
[ 4.077514] systemd[1]: Starting udev Kernel Socket.
[ 4.078651] systemd[1]: Listening on udev Kernel Socket.
[ 4.078995] systemd[1]: Starting /dev/initctl Compatibility Named Pipe.
[ 4.081632] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[ 4.082028] systemd[1]: Starting Journal Socket.
[ 4.082112] systemd[1]: Socket service systemd-journald.service not loaded, refusing.
[ 4.089461] systemd[1]: Failed to listen on Journal Socket.
[ 4.091497] systemd[1]: Starting System Slice.
[ 4.096236] systemd[1]: Created slice System Slice.
[ 4.096751] systemd[1]: Started File System Check on Root Device.
[ 4.097462] systemd[1]: Mounting Temporary Directory...
[ 4.106741] systemd[1]: Starting system-netctl\x2difplugd.slice.
[ 4.117268] systemd[1]: Created slice system-netctl\x2difplugd.slice.
[ 4.117623] systemd[1]: Starting system-getty.slice.
[ 4.124336] systemd[1]: Created slice system-getty.slice.
[ 4.134981] systemd[1]: Started Set Up Additional Binary Formats.
[ 4.135491] systemd[1]: Starting udev Coldplug all Devices...
[ 4.169884] systemd[1]: Starting Load Kernel Modules...
[ 4.185367] systemd[1]: Mounted Huge Pages File System.
[ 4.185802] systemd[1]: Starting Setup Virtual Console...
[ 4.241662] systemd[1]: Mounting Debug File System...
[ 4.280617] systemd[1]: Mounting POSIX Message Queue File System...
[ 4.302869] systemd-modules-load[64]: Module 'nfs' is builtin
[ 4.328517] bcm2708_rng_init=df80a000
[ 4.333911] systemd[1]: Starting Create list of required static device nodes for the current kernel...
[ 4.336296] systemd-modules-load[64]: Inserted module 'bcm2708_rng'
[ 4.411618] systemd[1]: Starting Slices.
[ 4.436811] systemd[1]: Reached target Slices.
[ 4.438731] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 4.477959] systemd-modules-load[64]: Inserted module 'snd_bcm2835'
[ 4.515086] systemd[1]: Mounted POSIX Message Queue File System.
[ 4.518132] systemd[1]: Mounted Debug File System.
[ 4.528937] systemd[1]: Mounted Temporary Directory.
[ 4.560236] systemd[1]: Started Load Kernel Modules.
[ 4.577872] systemd[1]: Started Setup Virtual Console.
[ 4.588498] systemd[1]: Started Create list of required static device nodes for the current kernel.
[ 4.827454] systemd[1]: Started udev Coldplug all Devices.
[ 5.241382] systemd[1]: Mounted FUSE Control File System.
[ 5.242412] systemd[1]: Mounting Configuration File System...
[ 5.250561] systemd[1]: Starting Apply Kernel Variables...
[ 5.305064] systemd[1]: Mounted Configuration File System.
[ 6.827869] EXT4-fs (mmcblk0p5): Mount option "nouser_xattr" will be removed by 3.5
Contact linux-ext4@vger.kernel.org if you think we should keep it.
[ 6.827943] EXT4-fs (mmcblk0p5): re-mounted. Opts: nouser_xattr,errors=remount-ro
[ 6.851503] systemd[1]: Started Remount Root and Kernel File Systems.
[ 6.857424] systemd[1]: Started Rebuild Dynamic Linker Cache.
[ 6.857867] systemd[1]: Started Rebuild Hardware Database.
[ 6.858119] systemd[1]: Starting Load/Save Random Seed...
[ 6.885532] systemd[1]: Started Create System Users.
[ 6.886119] systemd[1]: Started First Boot Wizard.
[ 6.887175] systemd[1]: Starting Create Static Device Nodes in /dev...
[ 6.938215] systemd[1]: Started Apply Kernel Variables.
[ 7.019615] systemd[1]: Started Load/Save Random Seed.
[ 7.081790] systemd[1]: Started Create Static Device Nodes in /dev.
[ 7.280247] systemd[1]: Starting udev Kernel Device Manager...
[ 7.288497] systemd[1]: Starting Local File Systems (Pre).
[ 7.297284] systemd[1]: Reached target Local File Systems (Pre).
[ 7.297798] systemd[1]: Mounting /var/log...
[ 7.304264] systemd[1]: var-log.mount: Directory /var/log to mount over is not empty, mounting anyway.
[ 7.346294] systemd-udevd[89]: starting version 216
[ 7.350789] systemd[1]: Started udev Kernel Device Manager.
[ 7.374263] systemd[1]: Mounted /var/log.
[ 7.511518] systemd[1]: Mounting /var/log/runeaudio...
[ 7.574260] systemd[1]: Mounted /var/log/runeaudio.
[ 7.999135] bcm2708_i2c_init_pinmode(0,0)
[ 7.999165] bcm2708_i2c_init_pinmode(0,1)
[ 7.999453] bcm2708_i2c bcm2708_i2c.0: BSC0 Controller at 0x20205000 (irq 79) (baudrate 100000)
[ 8.015550] bcm2708_i2c_init_pinmode(1,2)
[ 8.015581] bcm2708_i2c_init_pinmode(1,3)
[ 8.016159] bcm2708_i2c bcm2708_i2c.1: BSC1 Controller at 0x20804000 (irq 79) (baudrate 100000)
[ 8.055069] bcm2708_spi bcm2708_spi.0: master is unqueued, this is deprecated
[ 8.058652] bcm2708_spi bcm2708_spi.0: SPI Controller at 0x20204000 (irq 80)
[ 8.400396] bcm2708-i2s bcm2708-i2s.0: Failed to create debugfs directory
[ 8.617494] systemd[1]: Found device SMSC9512/9514 Fast Ethernet Adapter.
[ 8.673857] systemd[1]: Found device /dev/mmcblk0p1.
[ 8.690916] systemd[1]: Mounting /boot...
[ 8.969816] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ 8.991182] systemd[1]: Mounted /boot.
[ 9.125060] systemd[1]: Starting Local File Systems.
[ 9.132391] systemd[1]: Reached target Local File Systems.
[ 9.132946] systemd[1]: Started Rebuild Journal Catalog.
[ 9.133490] systemd[1]: Started Update is Completed.
[ 9.133721] systemd[1]: Starting Create Volatile Files and Directories...
[ 9.264137] systemd[1]: Started Create Volatile Files and Directories.
[ 9.265187] systemd[1]: Starting Update UTMP about System Boot/Shutdown...
[ 9.492320] systemd[1]: Started Update UTMP about System Boot/Shutdown.
[ 9.741124] systemd[1]: Starting System Initialization.
[ 9.751870] systemd[1]: Reached target System Initialization.
[ 9.752297] systemd[1]: Starting Daily verification of password and group files.
[ 9.757999] systemd[1]: Started Daily verification of password and group files.
[ 9.758346] systemd[1]: Starting Daily rotation of log files.
[ 9.759594] systemd[1]: Started Daily rotation of log files.
[ 9.759920] systemd[1]: Starting Avahi mDNS/DNS-SD Stack Activation Socket.
[ 9.767267] systemd[1]: Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
[ 9.767665] systemd[1]: Starting D-Bus System Message Bus Socket.
[ 9.773233] systemd[1]: Listening on D-Bus System Message Bus Socket.
[ 9.773675] systemd[1]: Starting Daily Cleanup of Temporary Directories.
[ 9.774027] systemd[1]: Started Daily Cleanup of Temporary Directories.
[ 9.774343] systemd[1]: Starting Timers.
[ 9.779312] systemd[1]: Reached target Timers.
[ 9.779822] systemd[1]: Started Manage Sound Card State (restore and store).
[ 9.780123] systemd[1]: Starting Restore Sound Card State...
[ 9.806276] systemd[1]: Starting RPCbind Server Activation Socket.
[ 9.816802] systemd[1]: Listening on RPCbind Server Activation Socket.
[ 9.817355] systemd[1]: Starting Sockets.
[ 9.826231] systemd[1]: Reached target Sockets.
[ 9.826626] systemd[1]: Starting Basic System.
[ 9.833862] systemd[1]: Reached target Basic System.
[ 9.834250] systemd[1]: Starting A high performance web server and a reverse proxy server...
[ 9.864419] systemd[1]: Started SSH Key Generation.
[ 9.864810] systemd[1]: Starting OpenSSH Daemon...
[ 9.936433] systemd[1]: Started OpenSSH Daemon.
[ 9.943284] systemd[1]: Starting Advanced key-value store...
[ 10.005410] systemd[1]: Started Advanced key-value store.
[ 10.006077] systemd[1]: Starting RuneAudio Playback Worker After=network.target...
[ 10.071289] systemd[1]: Started RuneAudio Playback Worker After=network.target.
[ 10.071851] systemd[1]: Starting The PHP FastCGI Process Manager...
[ 10.406819] usbcore: registered new interface driver rtl8192cu
[ 10.983089] systemd[1]: Starting Avahi DNS Configuration Daemon...
[ 11.054367] systemd[1]: Started Avahi DNS Configuration Daemon.
[ 11.054909] systemd[1]: Starting Automatic wired network connection using netctl profiles...
[ 11.117278] systemd[1]: Started Automatic wired network connection using netctl profiles.
[ 11.117960] systemd[1]: Starting Permit User Sessions...
[ 11.196742] systemd[1]: Starting Avahi mDNS/DNS-SD Stack...
[ 11.289057] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[ 11.320629] systemd[1]: Starting D-Bus System Message Bus...
[ 11.440715] systemd[1]: Started D-Bus System Message Bus.
[ 12.037365] systemd[1]: Started Avahi mDNS/DNS-SD Stack.
[ 12.038413] systemd[1]: Starting RPC bind service...
[ 12.145269] systemd[1]: Started Restore Sound Card State.
[ 12.232801] systemd[1]: Started Permit User Sessions.
[ 12.557244] systemd[1]: Started RPC bind service.
[ 12.587385] systemd[1]: Started A high performance web server and a reverse proxy server.
[ 12.792096] systemd[1]: Started The PHP FastCGI Process Manager.
[ 12.821266] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0xC5E1
[ 13.500762] systemd[1]: Starting Getty on tty1...
[ 13.523969] systemd[1]: Started Getty on tty1.
[ 13.524546] systemd[1]: Starting Login Prompts.
[ 13.526680] systemd[1]: Reached target Login Prompts.
[ 13.527274] systemd[1]: Starting Multi-User System.
[ 13.529352] systemd[1]: Reached target Multi-User System.
[ 13.529779] systemd[1]: Starting RuneAudio System Worker...
[ 13.547454] systemd[1]: Started RuneAudio System Worker.
[ 13.548078] systemd[1]: Starting Graphical Interface.
[ 13.550309] systemd[1]: Reached target Graphical Interface.
[ 13.557537] systemd[1]: Startup finished in 2.823s (kernel) + 10.726s (userspace) = 13.550s.
[ 16.297962] systemd[1]: Stopping The PHP FastCGI Process Manager...
[ 16.422765] systemd[1]: Stopped The PHP FastCGI Process Manager.
[ 16.831297] cfg80211: Calling CRDA to update world regulatory domain
[ 16.992256] systemd[1]: Starting Music Player Daemon...
[ 17.008663] systemd[1]: Started Music Player Daemon.
[ 17.503671] systemd[1]: Stopping Music Player Daemon...
[ 17.539682] systemd[1]: Stopped Music Player Daemon.
[ 18.037330] systemd[1]: Starting Samba SMB/CIFS server...
[ 18.043398] systemd[1]: Started Samba SMB/CIFS server.
[ 18.568976] systemd[1]: Starting Samba SMB/CIFS server...
[ 18.575609] systemd[1]: Started Samba SMB/CIFS server.
[ 18.985388] systemd[1]: Starting Music Player Daemon...
[ 18.992030] systemd[1]: Started Music Player Daemon.
[ 19.022317] systemd[1]: Starting Samba NetBIOS name server...
[ 19.068891] systemd[1]: Started Samba NetBIOS name server.
[ 19.610070] systemd[1]: Starting Samba NetBIOS name server...
[ 19.617686] systemd[1]: Started Samba NetBIOS name server.
[ 21.349721] systemd[1]: Starting Sound Card.
[ 21.349968] systemd[1]: Reached target Sound Card.
[ 21.477209] snd-hifiberry-dac snd-hifiberry-dac.0: pcm5102a-hifi <-> bcm2708-i2s.0 mapping ok
[ 23.517637] systemd[1]: Stopped Music Player Daemon.
[ 24.638687] systemd[1]: Starting Music Player Daemon...
[ 24.644910] systemd[1]: Started Music Player Daemon.
[ 24.875143] systemd[1]: Stopping Music Player Daemon...
[ 24.891467] systemd[1]: Stopped Music Player Daemon.
[ 26.046081] systemd[1]: Starting Music Player Daemon...
[ 26.053164] systemd[1]: Started Music Player Daemon.
[ 26.320058] systemd[1]: Started Music Player Daemon.
[ 28.220594] systemd[1]: Stopped Music Player Daemon.
[ 29.437371] systemd[1]: Starting Music Player Daemon...
[ 29.443588] systemd[1]: Started Music Player Daemon.
[ 30.777608] systemd[1]: Stopping Music Player Daemon...
[ 30.791244] systemd[1]: Starting Shairport AirTunes receiver...
[ 30.811402] systemd[1]: Started Shairport AirTunes receiver.
[ 30.881995] systemd[1]: Stopped Music Player Daemon.
[ 31.186475] systemd[1]: Starting Usb Automount (udevil)...
[ 31.192980] systemd[1]: Started Usb Automount (udevil).
[ 31.373669] systemd[1]: Time has been changed
[ 32.201949] systemd[1]: Starting Music Player Daemon...
[ 32.215346] systemd[1]: Started Music Player Daemon.
[ 32.684387] usbcore: registered new interface driver snd-usb-audio
[ 33.217651] bcm2835-cpufreq: switching to governor performance
[ 33.217687] bcm2835-cpufreq: switching to governor performance
[ 33.424956] systemd[1]: Starting The PHP FastCGI Process Manager...
[ 33.659830] systemd[1]: Started The PHP FastCGI Process Manager.
[ 34.142387] FS-Cache: Netfs 'cifs' registered for caching
[ 34.143299] Key type cifs.spnego registered
[ 34.143444] Key type cifs.idmap registered
[ 36.971905] systemd[1]: Stopped Music Player Daemon.
[ 38.086245] systemd[1]: Starting Music Player Daemon...
[ 38.093626] systemd[1]: Started Music Player Daemon.
[ 41.076488] CIFS VFS: Autodisabling the use of server inode numbers on \\192.168.1.1\thakmusic. This server doesn't seem to support them properly. Hardlinks will not be recognized on this mount. Consider mounting with the "noserverino" option to silence this message.
[ 44.664654] systemd[1]: Starting system-wpa_supplicant.slice.
[ 44.669346] systemd[1]: Created slice system-wpa_supplicant.slice.
[ 44.669965] systemd[1]: Starting WPA supplicant daemon (interface-specific version)...
[ 44.676259] systemd[1]: Started WPA supplicant daemon (interface-specific version).
[ 44.915170] systemd[1]: wpa_supplicant@wlan0.service: main process exited, code=exited, status=255/n/a
[ 44.938552] systemd[1]: Unit wpa_supplicant@wlan0.service entered failed state.
[ 46.260181] systemd[1]: Starting WPA supplicant daemon (interface-specific version)...
[ 46.266741] systemd[1]: Started WPA supplicant daemon (interface-specific version).
[ 46.379058] systemd[1]: wpa_supplicant@wlan0.service: main process exited, code=exited, status=255/n/a
[ 46.384682] systemd[1]: Unit wpa_supplicant@wlan0.service entered failed state.
[ 47.010288] systemd[1]: Starting system-netctl.slice.
[ 47.013350] systemd[1]: Created slice system-netctl.slice.
[ 47.013962] systemd[1]: Starting Networking for netctl profile wlan0...
[ 68.876464] systemd[1]: netctl@wlan0.service: main process exited, code=exited, status=1/FAILURE
[ 68.889139] systemd[1]: Failed to start Networking for netctl profile wlan0.
[ 68.894590] systemd[1]: Unit netctl@wlan0.service entered failed state.
[ 69.207482] systemd[1]: Starting WPA supplicant daemon (interface-specific version)...
[ 69.214025] systemd[1]: Started WPA supplicant daemon (interface-specific version).
[ 69.247941] systemd[1]: Starting Network.
[ 69.248196] systemd[1]: Reached target Network.
[ 69.328248] systemd[1]: wpa_supplicant@wlan0.service: main process exited, code=exited, status=255/n/a
[ 69.333848] systemd[1]: Unit wpa_supplicant@wlan0.service entered failed state.
###### PHP backend ######
php version: 5.5.17
debug level: 0
Debug data collected in 2.958 seconds.
