skrodahl wrote
The button you are referring to is a momentary button. It will be on as long as you hold it in, then, as soon as you release it, it will be off. You will need a latching button, one that stays on until you push it again to turn it off.
I thought I had found one of these buttons and the descrition said push once - on, push again - off, but can't seem to find it now and obviously linked to a different one. I'd had a long day so I'm probably mistaken.
Anyway i really need a power switch that is accessible from the front. It's just not going to be practical to have a button on the back or to disconnect the power cord with my rack and the way everything is set up. I calculate that I can get an approx 27mm space at the front of the case if the pi is hard up against the rear and the power supply is hard up against the pi. So Im looking fo a "short" switch. It doesn't need to be a fancy led one.
I'll put a pic up of the " big" case with pi and power in it tonight or tomorrow. I'm now thinking of using this case for a TPA3116 + pi but would have to use an external power supply for the amp.
