Hi Rod,
Sorry, I'm a noob at Arch Linux and have managed to get the Pi Zero W working by hacking together instructions from other, more knowledgeable souls. When I was at the point where I got RuneAudio working on the Pi Zero W but with a USB Wi-Fi adapter, not the on-board one, I found this link which suggested a way forward
https://archlinuxarm.org/forum/viewtopic.php?f=65&t=9938
Knowing that the Zero W and the Pi 3 use the same Wi-Fi/Bluetooth chip, I tried to follow the hints in the article and ended up copying the following to /lib/firmware/brcm
https://github.com/RPi-Distro/firmware-nonfree/raw/master/brcm80211/brcm/brcmfmac43430-sdio.bin
https://github.com/RPi-Distro/firmware-nonfree/raw/master/brcm80211/brcm/brcmfmac43430-sdio.txt
However, I couldn't do the suggested next step (chickened out after reading the warnings) which was to run rpi-update so it was unsuccessful. It was only after following the hints on the Pimoroni forum that I got the onboard Wi-Fi working. And yes, I overwrote the contents of the /boot directory instead of replacing it with the cloned one.
Not sure if it will help you but here is the output from dmesg on my Zero W
[root@runeaudio-zero ~]# dmesg
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.9.13+ (dc4@dc4-XPS13-9333) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611) ) #974 Wed Mar 1 20:04:40 GMT 2017
[ 0.000000] CPU: ARMv6-compatible processor [410fb767] revision 7 (ARMv7), cr=00c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
[ 0.000000] OF: fdt:Machine model: Raspberry Pi Zero W Rev 1.1
[ 0.000000] cma: Reserved 8 MiB at 0x1e400000
[ 0.000000] Memory policy: Data cache writeback
[ 0.000000] On node 0 totalpages: 126976
[ 0.000000] free_area_init_node: node 0, pgdat c09147b4, node_mem_map ddfa4000
[ 0.000000] Normal zone: 1116 pages used for memmap
[ 0.000000] Normal zone: 126976 pages, LIFO batch:31
[ 0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
[ 0.000000] pcpu-alloc: [0] 0
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 125860
[ 0.000000] Kernel command line: 8250.nr_uarts=0 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2708_fb.fbdepth=16 bcm2708_fb.fbswap=1 smsc95xx.macaddr=B8:27:EB:FD:12:F6 vc_mem.mem_base=0x1fa00000 vc_mem.mem_size=0x20000000 root=/dev/mmcblk0p5 rw rootwait console=ttyS0,115200 console=tty1 selinux=0 plymouth.enable=0 smsc95xx.turbo_mode=N dwc_otg.lpm_enable=0 kgdboc=ttyS0,115200 elevator=noop
[ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Memory: 484648K/507904K available (5941K kernel code, 489K rwdata, 1948K rodata, 404K init, 734K bss, 15064K reserved, 8192K cma-reserved)
vmalloc : 0xdf800000 - 0xff800000 ( 512 MB)
lowmem : 0xc0000000 - 0xdf000000 ( 496 MB)
modules : 0xbf000000 - 0xc0000000 ( 16 MB)
.text : 0xc0008000 - 0xc05d569c (5942 kB)
.init : 0xc083f000 - 0xc08a4000 ( 404 kB)
.data : 0xc08a4000 - 0xc091e680 ( 490 kB)
.bss : 0xc091e680 - 0xc09d5ee8 ( 735 kB)
[ 0.000000] SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] NR_IRQS:16 nr_irqs:16 16
[ 0.000028] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 2147483647500ns
[ 0.000072] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275 ns
[ 0.000172] bcm2835: system timer (irq = 27)
[ 0.000726] Console: colour dummy device 80x30
[ 0.001544] console [tty1] enabled
[ 0.001601] Calibrating delay loop... 697.95 BogoMIPS (lpj=3489792)
[ 0.060341] pid_max: default: 32768 minimum: 301
[ 0.060798] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.060868] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.061982] Disabling cpuset control group subsystem
[ 0.062258] CPU: Testing write buffer coherency: ok
[ 0.062368] ftrace: allocating 21710 entries in 64 pages
[ 0.176375] Setting up static identity map for 0x8200 - 0x8238
[ 0.178475] devtmpfs: initialized
[ 0.189968] VFP support v0.3: implementor 41 architecture 1 part 20 variant b rev 5
[ 0.190467] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.190568] futex hash table entries: 256 (order: -1, 3072 bytes)
[ 0.191883] pinctrl core: initialized pinctrl subsystem
[ 0.193438] NET: Registered protocol family 16
[ 0.196138] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[ 0.206225] hw-breakpoint: found 6 breakpoint and 1 watchpoint registers.
[ 0.206318] hw-breakpoint: maximum watchpoint size is 4 bytes.
[ 0.206466] Serial: AMBA PL011 UART driver
[ 0.211285] bcm2835-mbox 2000b880.mailbox: mailbox enabled
[ 0.212089] uart-pl011 20201000.serial: could not find pctldev for node /soc/gpio@7e200000/uart0_pins, deferring probe
[ 0.261282] bcm2835-dma 20007000.dma: DMA legacy API manager at df80d000, dmachans=0x1
[ 0.263870] SCSI subsystem initialized
[ 0.264202] usbcore: registered new interface driver usbfs
[ 0.264370] usbcore: registered new interface driver hub
[ 0.264607] usbcore: registered new device driver usb
[ 0.266412] raspberrypi-firmware soc:firmware: Attached to firmware from 2017-03-02 15:33
[ 0.268459] clocksource: Switched to clocksource timer
[ 0.325317] VFS: Disk quotas dquot_6.6.0
[ 0.325513] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.325844] FS-Cache: Loaded
[ 0.326252] CacheFiles: Loaded
[ 0.345991] NET: Registered protocol family 2
[ 0.347446] TCP established hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.347605] TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.347739] TCP: Hash tables configured (established 4096 bind 4096)
[ 0.347870] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 0.347938] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 0.348298] NET: Registered protocol family 1
[ 0.349201] RPC: Registered named UNIX socket transport module.
[ 0.349282] RPC: Registered udp transport module.
[ 0.349323] RPC: Registered tcp transport module.
[ 0.349362] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.350628] hw perfevents: enabled with armv6_1176 PMU driver, 3 counters available
[ 0.353155] workingset: timestamp_bits=14 max_order=17 bucket_order=3
[ 0.373237] FS-Cache: Netfs 'nfs' registered for caching
[ 0.375092] NFS: Registering the id_resolver key type
[ 0.375199] Key type id_resolver registered
[ 0.375243] Key type id_legacy registered
[ 0.379832] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 251)
[ 0.380303] io scheduler noop registered (default)
[ 0.380372] io scheduler deadline registered
[ 0.380841] io scheduler cfq registered
[ 0.386916] BCM2708FB: allocated DMA memory 5e500000
[ 0.387046] BCM2708FB: allocated DMA channel 0 @ df80d000
[ 0.392492] Console: switching to colour frame buffer device 82x26
[ 0.400498] bcm2835-rng 20104000.rng: hwrng registered
[ 0.402338] vc-cma: Videocore CMA driver
[ 0.403899] vc-cma: vc_cma_base = 0x00000000
[ 0.405432] vc-cma: vc_cma_size = 0x00000000 (0 MiB)
[ 0.406988] vc-cma: vc_cma_initial = 0x00000000 (0 MiB)
[ 0.409113] vc-mem: phys_addr:0x00000000 mem_base=0x1fa00000 mem_size:0x20000000(512 MiB)
[ 0.437610] brd: module loaded
[ 0.451639] loop: module loaded
[ 0.453170] Loading iSCSI transport class v2.0-870.
[ 0.455596] usbcore: registered new interface driver smsc95xx
[ 0.457133] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 0.684978] Core Release: 2.80a
[ 0.686502] Setting default values for core params
[ 0.687930] Finished setting default values for core params
[ 0.889770] Using Buffer DMA mode
[ 0.891239] Periodic Transfer Interrupt Enhancement - disabled
[ 0.892717] Multiprocessor Interrupt Enhancement - disabled
[ 0.894198] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 0.895746] Dedicated Tx FIFOs mode
[ 0.897795] WARN::dwc_otg_hcd_init:1053: FIQ DMA bounce buffers: virt = 0xde514000 dma = 0x5e514000 len=9024
[ 0.900953] FIQ FSM acceleration enabled for :
Periodic Split Transactions
High-Speed Isochronous Endpoints
Interrupt/Control Split Transaction hack enabled
[ 0.908669] dwc_otg: Microframe scheduler enabled
[ 0.908802] WARN::hcd_init_fiq:459: FIQ on core 0 at 0xc04503a0
[ 0.910424] WARN::hcd_init_fiq:460: FIQ ASM at 0xc045067c length 36
[ 0.912024] WARN::hcd_init_fiq:486: MPHI regs_base at 0xdf8a7000
[ 0.913672] dwc_otg 20980000.usb: DWC OTG Controller
[ 0.915298] dwc_otg 20980000.usb: new USB bus registered, assigned bus number 1
[ 0.916996] dwc_otg 20980000.usb: irq 56, io mem 0x00000000
[ 0.918705] Init: Port Power? op_state=1
[ 0.920281] Init: Power Port (0)
[ 0.922148] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 0.923768] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.925339] usb usb1: Product: DWC OTG Controller
[ 0.926878] usb usb1: Manufacturer: Linux 4.9.13+ dwc_otg_hcd
[ 0.928421] usb usb1: SerialNumber: 20980000.usb
[ 0.931229] hub 1-0:1.0: USB hub found
[ 0.932890] hub 1-0:1.0: 1 port detected
[ 0.935279] dwc_otg: FIQ enabled
[ 0.935290] dwc_otg: NAK holdoff enabled
[ 0.935296] dwc_otg: FIQ split-transaction FSM enabled
[ 0.935315] Module dwc_common_port init
[ 0.935823] usbcore: registered new interface driver usb-storage
[ 0.937873] mousedev: PS/2 mouse device common for all mice
[ 0.941149] bcm2835-wdt 20100000.watchdog: Broadcom BCM2835 watchdog timer
[ 0.943351] bcm2835-cpufreq: min=700000 max=1000000
[ 0.945600] sdhci: Secure Digital Host Controller Interface driver
[ 0.947229] sdhci: Copyright(c) Pierre Ossman
[ 0.949521] sdhost: log_buf @ de513000 (5e513000)
[ 1.028528] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
[ 1.052983] mmc-bcm2835 20300000.mmc: mmc_debug:0 mmc_debug2:0
[ 1.054665] mmc-bcm2835 20300000.mmc: DMA channel allocated
[ 1.067000] random: fast init done
[ 1.108659] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.110870] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.112672] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.114547] usbcore: registered new interface driver usbhid
[ 1.116155] usbhid: USB HID core driver
[ 1.120141] vchiq: vchiq_init_state: slot_zero = 0xde580000, is_master = 0
[ 1.131427] Initializing XFRM netlink socket
[ 1.133404] NET: Registered protocol family 17
[ 1.135353] Key type dns_resolver registered
[ 1.139629] registered taskstats version 1
[ 1.147240] vc-sm: Videocore shared memory driver
[ 1.149155] [vc_sm_connected_init]: start
[ 1.151354] vc_vchi_sm_init: failed to open VCHI service (-1)
[ 1.151554] [vc_sm_connected_init]: failed to initialize shared memory service
[ 1.154740] [vc_sm_connected_init]: end - returning -1
[ 1.156387] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[ 1.160706] 20201000.serial: ttyAMA0 at MMIO 0x20201000 (irq = 81, base_baud = 0) is a PL011 rev2
[ 1.165376] of_cfs_init
[ 1.167284] of_cfs_init: OK
[ 1.169755] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 1.173503] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 1.176272] Waiting for root device /dev/mmcblk0p5...
[ 1.180483] mmc0: host does not support reading read-only switch, assuming write-enable
[ 1.184471] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[ 1.187155] mmc0: new high speed SDHC card at address aaaa
[ 1.190297] mmcblk0: mmc0:aaaa SL08G 7.40 GiB
[ 1.195974] mmcblk0: p1 p2 < p5 >
[ 1.291706] mmc1: new high speed SDIO card at address 0001
[ 1.293668] EXT4-fs (mmcblk0p5): couldn't mount as ext3 due to feature incompatibilities
[ 1.298623] EXT4-fs (mmcblk0p5): couldn't mount as ext2 due to feature incompatibilities
[ 1.319742] EXT4-fs (mmcblk0p5): mounted filesystem with ordered data mode. Opts: (null)
[ 1.323469] VFS: Mounted root (ext4 filesystem) on device 179:5.
[ 1.334107] devtmpfs: mounted
[ 1.337201] Freeing unused kernel memory: 404K (c083f000 - c08a4000)
[ 1.339149] This architecture does not have kernel memory protection.
[ 1.655080] systemd[1]: systemd 216 running in system mode. (+PAM -AUDIT -SELINUX -IMA -APPARMOR +SMACK -SYSVINIT +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ -LZ4 +SECCOMP +BLKID -ELFUTILS +KMOD -IDN )
[ 1.661976] systemd[1]: Detected architecture 'arm'.
[ 1.820872] NET: Registered protocol family 10
[ 1.824840] systemd[1]: Inserted module 'ipv6'
[ 1.829826] systemd[1]: Set hostname to <runeaudio-zero>.
[ 2.508875] systemd[1]: Cannot add dependency job for unit display-manager.service, ignoring: Unit display-manager.service failed to load: No such file or directory.
[ 2.525460] systemd[1]: Starting Forward Password Requests to Wall Directory Watch.
[ 2.530329] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 2.534472] systemd[1]: Starting Remote File Systems.
[ 2.539347] systemd[1]: Reached target Remote File Systems.
[ 2.541665] systemd[1]: Expecting device sys-subsystem-net-devices-wlan0.device...
[ 2.960226] systemd-modules-load[84]: Module 'nfs' is builtin
[ 2.963598] systemd-modules-load[84]: Failed to find module 'bcm2708-rng'
[ 3.055221] systemd-modules-load[84]: Inserted module 'snd_bcm2835'
[ 3.202504] EXT4-fs (mmcblk0p5): Mount option "nouser_xattr" will be removed by 3.5
Contact linux-ext4@vger.kernel.org if you think we should keep it.
[ 3.228688] EXT4-fs (mmcblk0p5): re-mounted. Opts: nouser_xattr,errors=remount-ro
[ 4.539027] systemd-udevd[108]: starting version 216
[ 5.322423] gpiomem-bcm2835 20200000.gpiomem: Initialised: Registers at 0x20200000
[ 5.624984] snd-rpi-iqaudio-dac soc:sound: ASoC: CPU DAI (null) not registered - will retry
[ 5.629911] snd-rpi-iqaudio-dac soc:sound: ASoC: CODEC DAI pcm512x-hifi not registered - will retry
[ 5.864798] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ 6.012551] snd-rpi-iqaudio-dac soc:sound: ASoC: CODEC DAI pcm512x-hifi not registered - will retry
[ 6.039149] usbcore: registered new interface driver brcmfmac
[ 6.040865] snd-rpi-iqaudio-dac soc:sound: ASoC: CODEC DAI pcm512x-hifi not registered - will retry
[ 6.242904] brcmfmac: Firmware version = wl0: May 27 2016 00:13:38 version 7.45.41.26 (r640327) FWID 01-df77e4a7
[ 6.676688] systemd[1]: Starting System Initialization.
[ 6.684776] systemd[1]: Reached target System Initialization.
[ 6.685218] systemd[1]: Starting Daily verification of password and group files.
[ 6.699145] systemd[1]: Started Daily verification of password and group files.
[ 6.699528] systemd[1]: Starting Daily rotation of log files.
[ 6.700676] systemd[1]: Started Daily rotation of log files.
[ 6.701021] systemd[1]: Starting Avahi mDNS/DNS-SD Stack Activation Socket.
[ 6.708803] systemd[1]: Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
[ 6.709230] systemd[1]: Starting D-Bus System Message Bus Socket.
[ 6.716577] systemd[1]: Listening on D-Bus System Message Bus Socket.
[ 7.499302] snd-rpi-iqaudio-dac soc:sound: pcm512x-hifi <-> 20203000.i2s mapping ok
[ 9.594635] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 9.594654] brcmfmac: power management disabled
[ 10.600426] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 11.805415] systemd[1]: Starting Multi-User System.
[ 11.816179] systemd[1]: Reached target Multi-User System.
[ 11.816542] systemd[1]: Starting RuneAudio System Worker...
[ 11.887785] systemd[1]: Started RuneAudio System Worker.
[ 11.888433] systemd[1]: Starting Graphical Interface.
[ 11.899111] systemd[1]: Reached target Graphical Interface.
[ 11.907789] systemd[1]: Startup finished in 1.513s (kernel) + 10.316s (userspace) = 11.829s.
[ 13.740727] systemd[1]: Stopping The PHP FastCGI Process Manager...
[ 13.791418] systemd[1]: Stopped The PHP FastCGI Process Manager.
[ 14.122038] systemd[1]: Starting Music Player Daemon...
[ 17.052313] systemd[1]: Starting Upmpdcli UPnP/DLNA receiver...
[ 17.060244] systemd[1]: Started Upmpdcli UPnP/DLNA receiver.
[ 17.954480] systemd[1]: rune_PL_wrk.service: main process exited, code=exited, status=255/n/a
[ 17.972854] systemd[1]: Unit rune_PL_wrk.service entered failed state.
[ 18.334890] systemd[1]: mpd.service holdoff time over, scheduling restart.
[ 18.341345] systemd[1]: Stopping Upmpdcli UPnP/DLNA receiver...
[ 18.438173] systemd[1]: Stopping Music Player Daemon...
[ 18.438803] systemd[1]: Starting Music Player Daemon...
[ 18.446673] systemd[1]: Started Music Player Daemon.
[ 18.447280] systemd[1]: Starting Upmpdcli UPnP/DLNA receiver...
[ 22.327459] systemd[1]: Starting Usb Automount (udevil)...
[ 22.365416] systemd[1]: Started Usb Automount (udevil).
[ 27.001716] systemd[1]: Starting The PHP FastCGI Process Manager...
[ 27.658103] systemd[1]: Started The PHP FastCGI Process Manager.
[ 28.873814] brcmfmac: power management disabled
[ 30.699637] FS-Cache: Netfs 'cifs' registered for caching
[ 30.703376] Key type cifs.spnego registered
[ 30.703415] Key type cifs.idmap registered
[ 35.600522] systemd[1]: Reloading.
[ 41.851201] random: crng init done
[ 173.931450] systemd[1]: rune_PL_wrk.service: main process exited, code=exited, status=255/n/a
[ 173.937231] systemd[1]: Unit rune_PL_wrk.service entered failed state.
[ 174.308783] pcm512x 1-004c: No SCLK, using BCLK: -2
[ 175.084450] systemd[1]: rune_PL_wrk.service holdoff time over, scheduling restart.
[ 175.090915] systemd[1]: Stopping RuneAudio Playback Worker...
[ 175.091355] systemd[1]: Starting RuneAudio Playback Worker...
[ 176.290343] systemd[1]: Failed to reset devices.list on /system.slice: Invalid argument
[ 176.297649] systemd[1]: Started RuneAudio Playback Worker.
[ 556.619634] systemd[1]: rune_PL_wrk.service: main process exited, code=exited, status=255/n/a
[ 556.625494] systemd[1]: Unit rune_PL_wrk.service entered failed state.
[ 557.767076] systemd[1]: rune_PL_wrk.service holdoff time over, scheduling restart.
[ 557.772540] systemd[1]: Stopping RuneAudio Playback Worker...
[ 557.772974] systemd[1]: Starting RuneAudio Playback Worker...
[ 557.781519] systemd[1]: Started RuneAudio Playback Worker.
[ 907.803569] systemd[1]: Starting Cleanup of Temporary Directories...
[ 907.874271] systemd[1]: Started Cleanup of Temporary Directories.
[ 7348.612237] systemd[1]: Starting Rotate log files...
[ 7348.619902] systemd[1]: Starting Verify integrity of password and group files...
[ 7348.785718] systemd[1]: Started Rotate log files.
[ 7349.008809] systemd[1]: Started Verify integrity of password and group files.
[72133.455762] pcm512x 1-004c: No SCLK, using BCLK: -2
[72422.272496] systemd[1]: rune_PL_wrk.service: main process exited, code=exited, status=255/n/a
[72422.278611] systemd[1]: Unit rune_PL_wrk.service entered failed state.
[72423.415598] systemd[1]: rune_PL_wrk.service holdoff time over, scheduling restart.
[72423.425944] systemd[1]: Stopping RuneAudio Playback Worker...
[72423.430048] systemd[1]: Starting RuneAudio Playback Worker...
[72423.451462] systemd[1]: Started RuneAudio Playback Worker.
[72819.556980] systemd[1]: rune_PL_wrk.service: main process exited, code=exited, status=255/n/a
[72819.562964] systemd[1]: Unit rune_PL_wrk.service entered failed state.
[72820.670185] systemd[1]: rune_PL_wrk.service holdoff time over, scheduling restart.
[72820.676029] systemd[1]: Stopping RuneAudio Playback Worker...
[72820.676467] systemd[1]: Starting RuneAudio Playback Worker...
[72820.684584] systemd[1]: Started RuneAudio Playback Worker.
[73108.408354] systemd[1]: rune_PL_wrk.service: main process exited, code=exited, status=255/n/a
[73108.414242] systemd[1]: Unit rune_PL_wrk.service entered failed state.
[73109.423718] systemd[1]: rune_PL_wrk.service holdoff time over, scheduling restart.
[73109.432399] systemd[1]: Stopping RuneAudio Playback Worker...
[73109.432840] systemd[1]: Starting RuneAudio Playback Worker...
[73109.444416] systemd[1]: Started RuneAudio Playback Worker.
[73419.061797] systemd[1]: rune_PL_wrk.service: main process exited, code=exited, status=255/n/a
[73419.067846] systemd[1]: Unit rune_PL_wrk.service entered failed state.
[73420.177310] systemd[1]: rune_PL_wrk.service holdoff time over, scheduling restart.
[73420.183009] systemd[1]: Stopping RuneAudio Playback Worker...
[73420.183444] systemd[1]: Starting RuneAudio Playback Worker...
[73420.191780] systemd[1]: Started RuneAudio Playback Worker.
[73784.955897] systemd[1]: rune_PL_wrk.service: main process exited, code=exited, status=255/n/a
[73784.961759] systemd[1]: Unit rune_PL_wrk.service entered failed state.
[73786.181692] systemd[1]: rune_PL_wrk.service holdoff time over, scheduling restart.
[73786.187307] systemd[1]: Stopping RuneAudio Playback Worker...
[73786.187744] systemd[1]: Starting RuneAudio Playback Worker...
[73786.195762] systemd[1]: Started RuneAudio Playback Worker.
[74081.887103] systemd[1]: rune_PL_wrk.service: main process exited, code=exited, status=255/n/a
[74081.893576] systemd[1]: Unit rune_PL_wrk.service entered failed state.
[74082.935423] systemd[1]: rune_PL_wrk.service holdoff time over, scheduling restart.
[74082.942749] systemd[1]: Stopping RuneAudio Playback Worker...
[74082.943189] systemd[1]: Starting RuneAudio Playback Worker...
[74082.954280] systemd[1]: Started RuneAudio Playback Worker.
[74334.132221] systemd[1]: rune_PL_wrk.service: main process exited, code=exited, status=255/n/a
[74334.138118] systemd[1]: Unit rune_PL_wrk.service entered failed state.
[74335.188268] systemd[1]: rune_PL_wrk.service holdoff time over, scheduling restart.
[74335.193949] systemd[1]: Stopping RuneAudio Playback Worker...
[74335.194385] systemd[1]: Starting RuneAudio Playback Worker...
[74335.202505] systemd[1]: Started RuneAudio Playback Worker.
[74568.375662] systemd[1]: rune_PL_wrk.service: main process exited, code=exited, status=255/n/a
[74568.381638] systemd[1]: Unit rune_PL_wrk.service entered failed state.
[74569.441043] systemd[1]: rune_PL_wrk.service holdoff time over, scheduling restart.
[74569.446674] systemd[1]: Stopping RuneAudio Playback Worker...
[74569.447109] systemd[1]: Starting RuneAudio Playback Worker...
[74569.455235] systemd[1]: Started RuneAudio Playback Worker.
[74594.815839] systemd[1]: rune_PL_wrk.service: main process exited, code=exited, status=255/n/a
[74594.837265] systemd[1]: Unit rune_PL_wrk.service entered failed state.
[74595.058470] pcm512x 1-004c: No SCLK, using BCLK: -2
[74595.941553] systemd[1]: rune_PL_wrk.service holdoff time over, scheduling restart.
[74595.951839] systemd[1]: Stopping RuneAudio Playback Worker...
[74595.952279] systemd[1]: Starting RuneAudio Playback Worker...
[74595.993972] systemd[1]: Started RuneAudio Playback Worker.
[74935.921904] systemd[1]: rune_PL_wrk.service: main process exited, code=exited, status=255/n/a
[74935.927885] systemd[1]: Unit rune_PL_wrk.service entered failed state.
[74936.945619] systemd[1]: rune_PL_wrk.service holdoff time over, scheduling restart.
[74936.953591] systemd[1]: Stopping RuneAudio Playback Worker...
[74936.954028] systemd[1]: Starting RuneAudio Playback Worker...
[74936.985369] systemd[1]: Started RuneAudio Playback Worker.
[75240.136810] systemd[1]: rune_PL_wrk.service: main process exited, code=exited, status=255/n/a
[75240.142690] systemd[1]: Unit rune_PL_wrk.service entered failed state.
[75241.199056] systemd[1]: rune_PL_wrk.service holdoff time over, scheduling restart.
[75241.208459] systemd[1]: Stopping RuneAudio Playback Worker...
[75241.209703] systemd[1]: Starting RuneAudio Playback Worker...
[75241.231059] systemd[1]: Started RuneAudio Playback Worker.
[81463.208962] systemd[1]: rune_PL_wrk.service: main process exited, code=exited, status=255/n/a
[81463.216543] systemd[1]: Unit rune_PL_wrk.service entered failed state.
[81463.518370] pcm512x 1-004c: No SCLK, using BCLK: -2
[81464.238437] systemd[1]: rune_PL_wrk.service holdoff time over, scheduling restart.
[81464.244431] systemd[1]: Stopping RuneAudio Playback Worker...
[81464.244868] systemd[1]: Starting RuneAudio Playback Worker...
[81464.259003] systemd[1]: Started RuneAudio Playback Worker.
[81547.175308] systemd[1]: rune_PL_wrk.service: main process exited, code=exited, status=255/n/a
[81547.194242] systemd[1]: Unit rune_PL_wrk.service entered failed state.
[81547.740525] pcm512x 1-004c: No SCLK, using BCLK: -2
[81548.239396] systemd[1]: rune_PL_wrk.service holdoff time over, scheduling restart.
[81548.246598] systemd[1]: Stopping RuneAudio Playback Worker...
[81548.247036] systemd[1]: Starting RuneAudio Playback Worker...
[81548.258217] systemd[1]: Started RuneAudio Playback Worker.
[81566.906129] systemd[1]: rune_PL_wrk.service: main process exited, code=exited, status=255/n/a
[81566.938193] systemd[1]: Unit rune_PL_wrk.service entered failed state.
[81567.455784] pcm512x 1-004c: No SCLK, using BCLK: -2
[81567.989575] systemd[1]: rune_PL_wrk.service holdoff time over, scheduling restart.
[81568.009275] systemd[1]: Stopping RuneAudio Playback Worker...
[81568.009780] systemd[1]: Starting RuneAudio Playback Worker...
[81568.031689] systemd[1]: Started RuneAudio Playback Worker.
[81593.780020] pcm512x 1-004c: No SCLK, using BCLK: -2
About the dmesg errors you are getting, I found this advice here
https://www.raspberrypi.org/forums/viewtopic.php?f=28&t=138629
by garlicbready ยป Mon Mar 07, 2016 2:28 pm
First try the following
# Remove the Driver
modprobe -r brcmfmac
# Load in the Driver
modprobe brcmfmac
# Check Dmesg for any errors
dmesg
# List all network ports
ifconfig -a
If you see an error in the dmesg log like this, then your likley missing the needed firmware files
brcmfmac_sdio mmc1:0001:1: Direct firmware load for brcm/brcmfmac43430-sdio.bin failed with error -2
In that case go to
https://github.com/RPi-Distro/firmware- ... 80211/brcm
and download the brcmfmac43430-sdio.bin and brcmfmac43430-sdio.txt files into the directory
/lib/firmware/brcm/ then try again
RawDevice
