I've successfully got Rune to work on a PiZero with a hubpiwi, which adds wireless and 3 standard USB ports. Many thanks to hpeter and Frank, and to
rumina from the Head-Fi forum!
To get wifi going, I made a new profile in /etc/netctl with the same name as the SSID of my network, and then copied the settings of my profile from another installation of RuneAudio on a Pi3 to the new profile. I then entered the following command:
netctl-auto enable MYPROFILENAME
For some reason, hpeter's image was slightly larger than a Sandisk 8gb microSD card. I managed to load it on a 16gb card. I don't really know how to shrink a partition so any help on that using Windows or Rune itself would be appreciated, since I don't have an independent linux machine.
Also, I needed to install utilities to support exfat (necessary for large SD cards) and ntfs file systems. I installed the following:
for exfat
pacman -S exfat-utils
for ntfs
pacman -S ntfs-3g
I noticed that config.txt did not include the option to provide more power to USB. I added the following at the bottom:
max_usb_current=1
Has anyone tried Frank's suggested settings in config.txt for the Cpu:
arm_freq=1000
gpu_freq=300
core_freq=400
over_voltage=6
force_turbo=1
If so, do they work?
Rod
